Hot Rods 56 Chevy Rear Axle Ratio
Discussion in 'The Hokey Ass Message Board' started by brading, Feb 15, 2024.
  1. brading
    brading
    A friend of mine has a 56 Chevy with a speed box and overdrive, 4.11 ratio rear axle and at 50 mph the engine is doing 3000 rpm. He would like to know if putting a 3.7 ratio would be a good idea. He knows he would loose some acceleration I said I would ask on here for him as I know you guys are clued up on this sort of thing. Thank You
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    If it has overdrive just engage the OD that is what it is for....
  3. 1934coupe
    1934coupe
    Depends on what he wants, 3:70s would be great but if he has OD it seems odd that it does 3K at 50. Something seems off to me.
    Pat
    Truckdoctor Andy and Moriarity like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    the OD ratio is .7 so at 50 mph in OD with 4.11 the rpms will be 1700
    BJR, bchctybob, Johnny Gee and 5 others like this.
  5. 1934coupe
    1934coupe
    That sounds more like it Moriarity.
    Pat
    Moriarity likes this.
  6. 427 sleeper
    427 sleeper
    Sound's like the speedo is off. 50 mph with a 4.11 and 28" tall tire's should be 2500 rpm. 60 mph should be 3000 rpm.
  7. seb fontana
    seb fontana
    from ct
    28" tall tire is 2960 rpm with 4.11 gear at 60 mph, in od 2132.:D
    fastcar1953 likes this.
  8. miker98038
    miker98038
    He needs to find one of us Ford guys show him how the o/d works. Or show him how to troubleshoot it. Probably tougher in the UK.
    Tow Truck Tom likes this.
  9. bchctybob
    bchctybob
    If it’s a stock ‘56 Chevy transmission, Speedway has a good book on the Borg-Warner overdrive. That, and the factory manual might be good sources on the proper operation of the OD.
    427 sleeper and irishsteve like this.
  10. brading
    brading
    Thank you very much for the replies guys will pass this info onto him.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    is his overdrive not working? push the cable in, let off the gas in high gear at over 40 mph or so and it should shift into OD automatically
  12. brading
    brading
    From what I have read in this thread that what I was wondering. Am waiting for him to reply to my message and will let you know. Thanks
    seb fontana and Moriarity like this.
  13. miker98038
    miker98038
    Here’s a link to the originals o/d manual. I think it’s just the R-10, but the operation is the same as the R-11. Should be enough for anything short of a total rebuild, and it would get you thru the R-11 too if you’re mechanically experienced. Covers the electrical side too.
    http://www.oldwillysforum.com/forum/TechData/BWOverdriveManual.pdf
  14. brading
    brading
    Thanks for that "miker" will pass it on. Waiting for my mate to reply to what I have sent him already.
  15. jaracer
    jaracer
    Every overdrive I've seen, you have to push the cable in to allow the OD to work. Pulling it out locks out the overdrive. It slides the sun gear into the planet carrier effectively locking the OD gear set.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    you are right, my 55 has OD and I can't believe I screwed that up haha, I hate getting old. I am going to edit my post, thanks
