1952-59 Ford 56 customline build
Discussion in 'Off Topic Hot Rods & Customs' started by burdman1956, May 1, 2020.
  1. burdman1956
    burdman1956
    Been working on my 56 finally after almost 20 years of sitting. I have gotten so much info from this forum/group really giving me motivation on it. I’ve asked a few member questions everyone been helpful. Motor and ****** going in tomorrow or Sunday! It’s all ready! Got front end torn apart and at powder coating already test fit engine n ****** with different mounts and now tomorrow it will be 1. Here are some pics.. When I go to ***emble the front end and press bushings in is there a parts bread down book/manual I can double check n make sure it’s going together right direction? I have other things on car I’d like too look at also when re ***embling.. here are some progress pics
    bobss396 and Navyford like this.
  2. burdman1956
    burdman1956
    Motor pics, 331 t5 ****** should be all together tomorrow.
    JeffB2 and Navyford like this.
  3. 50sboy
    50sboy
    Nice work! And FAST. Funny...this Stay At Home stuff is allowing months of work in a few days!!
    JeffB2 and burdman1956 like this.
  4. 56FORD390
    56FORD390
    Is the floor shifter going to clear the front seat?
  5. burdman1956
    burdman1956
    Right, racing is canceled so race car can sit and money n time can go towards getting my car back together. I’m enjoying it and glad I dug in.
    JeffB2 likes this.
  6. burdman1956
    burdman1956
    Looks like it will. I mocked it up with 2 different motor mounts 2220/2221 didn’t fit the oil pan the fox body mounts moved it up and forward fits good. Looks like shifter hole gonna be right in front of seat, I’ll use a forward style shifter arm.
    JeffB2 likes this.
  7. bobss396
    bobss396
    Nice work. My major regret with my car was not do***enting things as they came apart. I only had a good camera late in the build. And whatever you bag up, mark the bag accordingly. You should have a shop manual, they are available on eBay and handy. One of the members, Dan, has a good CD that will help anyone.
  8. burdman1956
    burdman1956
    yea I took pic of the way the bushing where pressed in or direction I guess I should say but I question some of it especially the upper control arm, so I was wondering about parts break down or a manual. What’s dans name on here? Yea everything is bagged n tagged, and in boxes.
    JeffB2 likes this.
  9. evintho
    evintho
    burdman1956 and JeffB2 like this.
  10. burdman1956
    burdman1956
    Yay it’s in for good, now to make a crossmember when my ****** mount comes in. Next is putting the front suspention together and brake n fuel lines hooked up.
    Texas57 and 56longroof like this.
  11. guthriesmith
    guthriesmith
  12. burdman1956
    burdman1956
    Trans cross member made, going to work on running brake n fuel lines soon.
    guthriesmith and 56longroof like this.
  13. burdman1956
    burdman1956
    Got my water pump and pulley setup all on today, cvf stuff looks nice fits good. Started blasting the radiator support getting that ready to be put on. Have to order some more parts soon hopefully.
  14. Allout
    Allout
    Looking good!
    burdman1956 likes this.
  15. burdman1956
    burdman1956
    Progress! Got front end bushings and ball joints put together ***embled with areostar springs.. came out great.. test fitting headers.. got the 1 wire ford alt.. looks good. I think I might change the dust covers for ball joints from factory style to after market energy ones. The upper one I don’t understand the 3 washers n felt they seem out of order way it came. I might just get poly ones.
    56longroof and JeffB2 like this.
  16. burdman1956
    burdman1956
    Got the clutch hooked up, super simple took about an hour n half with paint. Works great pretty happy!!
  17. burdman1956
    burdman1956
    Had to get a peek at how she looks on the ground with Granada spindles with aero star springs. Not bad at all. I might need new leafs outback, the shackles are flipped right now and its only maybe couple inches high right now. We will see how that plays out. Was hoping to set it right and run it for now upgrade later. Funds are getting tight. Got clutch hooked up and brake lines ran, brakes in.. mile stone 1..
  18. danman55
    danman55
    My 55 dropped a bit more after I installed the entire front end sheet metal, bumper, gravel pan, etc. I have the Aerostar springs as well but I run a Y Block so I would my entire front end weight is a little heavier than what yours will be. I ended up adding a 1" hard rubber coil spacer (up into the frame cavity) and now I really like the ride!
    https://www.hotrodreverend.com/post/2019/09/13/1955-ford-part-84-tinkering-on-the-ford
  19. burdman1956
    burdman1956
    i put in a 5/8 spacer, I suspect after it settles and all the front clip on it it’ll be couple inches lower. Pretty happy with it, and the clutch pedal setup.
    56longroof likes this.
  20. 55newbie
    55newbie
    from Ohio
    Did you still have to slot the mounting pad on the crossmember when you used thenFox body mounts?
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    The reason we started advising the slots almost ten years ago is because we started finding out that the mount pads on the cross member in many cases were slightly off from the factory and this allows room for adjustment. On my '54 I only had to elongate one hole about a 1/4 inch on the p***enger side some members did no modifications but if you do the slots you won't have to do it later if they don't line up and pull the engine out of the way,so as Clint Eastwood said "Do you feel Lucky ?"
