Customs 56 f100 3 speed on the tree converting to automatic column with c4
Discussion in 'The Hokey Ass Message Board' started by Ammf6, Dec 29, 2020.
  1. Ammf6
    Ammf6
    So I’ve decided to convert my 3 speed on the tree y block truck to an automatic with a c4 auto . I’ve tracked down an original 1956 automatic column from a doner 56 , what else is needed to get it all put together for smooth sailing ??
    can I still use my peddle box if I remove the clutch peddle ?
    will I need an automatic steering box or can I use my one that’s currently on it ?
  2. fresh hops
    fresh hops
  3. mickeyc
    mickeyc
    I dont think there is any different box for an auto versus standard
    transmission. I replaced my 56 box with a 55 box in an automatic
    F-100. The 55 box was from a stick shift truck.
  4. Are you selling the old parts?
  5. The steering Box itself is the same between auto and stick. Take the rubber clutch pedal pad off and drop the arm to the floor and cover it with the Carpet and forget about it. No need to cut or change any of it.
    Irish Mike likes this.
  6. Ammf6
    Ammf6
    Thank you . Irish mike I’ll be keeping the parts for now .
    Does the indicator need a light ?
    Nutral safety switch hard to connect ?
  7. Ammf6
    Ammf6
  8. Something to look into before you install the new column. The index dog and stops are often worn down to almost useless due to drivers not lifting the handle to shift gears. It's often just a pull down motion. Now the time to fix it if yours is worn bad, It's just a little weld and file job and you'll be glad you did it. At that time you can also file a little more travel so you can actually get your C-4 into first gear. This is often what the shift index looks like.
    This unit is nearly worn clear through and useless to hold in gear. It can be fixed and is a lot easier before you install it.
  9. fresh hops
    fresh hops
    I did convert my 56 to automatic, but I went with an aftermarket tilt column.
  10. Ammf6
    Ammf6
    What auto did you convert to Fresh hops ?
    thanks piston broke I’ll keep that in mind I’ll try that trick
  11. fresh hops
    fresh hops
    I installed a 4L65E behind a LQ9 which is a the LS motor with a cast iron block. I wanted to put a coyote in but it was at least twice the cost and didn't even have half of the support from the aftermarket.
  12. Ammf6
    Ammf6
    anymore photos on this ,?
  13. The complete unit is laying in the Shop. What would you like to see or know?
