Hot Rods '56 F100 machine turned gauge cluster
Discussion in 'The Hokey Ass Message Board' started by Hardonsky23, Oct 18, 2017.
  1. Hardonsky23
    Hardonsky23
    Hi y'all. I've been building a '56 F100 and i've ran into a dilemma. About a year ago i sold my '55 cab and purchased a '56 cab to replace it. I had a machine-turned gauge cluster with Stewart-Warner gauges and gave the cluster away, but kept the gauges in hopes of using them in my new cab. Problem is, the company i bought my cluster from, egaugesplus.com, no longer carries a machine-turned cluster for a '56. Does anyone know where i can purchase a machine-turned gauge cluster for my truck?
  2. You might try Cl***ic Instruments or Mooneyes
  3. mgtstumpy
    mgtstumpy
    There is this product as a stop gap until you can locate a supplier?
    Here are some aluminum and steel panels in various sizes and patterns. A lot of shop fitters these days use engine turned sheets for design work so you might be fortunate to get an off cut from them or a sheet metal shop that with some minor work will do the job?
  4. cadillacoffin
    cadillacoffin
    fpm is a hamb vendor that offers this service out of nebraska. but i would ask the supplier that no longer carries the product your after for the file. if you can get the dwg/dxf file just send it to any shop with a laser. have to talk to the fab shop about getting the material.
    http://www.fpmmetals.com/
  5. indyjps
    indyjps
    If you have a drill press you can do it.
  6. Hardonsky23
    Hardonsky23
    Thanks for the help y'all. Not having much luck yet as i've contacted Mooneyes, Cl***ic Instruments, FPM, and Haneline with no response from any of them. I'm to the point if i could just find a plain panel cut for my gauges i'd try and do it myself.
  7. thall
    thall
    from nc
  8. HOTRODPRIMER
    HOTRODPRIMER
    I bought a piece of engine turned aluminum from Speedway motors and made mine. HRP
    Speedway Motors
  9. boring-hop-yard
    boring-hop-yard
  10. Hardonsky23
    Hardonsky23
    Still trying to find a quality gauge cluster for my truck. Never heard back from Mooneyes, Cl***ic Instruments, or FPM. Haneline looks like they have the best product out there with a polished aluminum backer and stainless steel insert, but they won't have one available for almost 6 months. I'm ***embling my dash right now so i can't wait that long. If i could wait i'd buy from Haneline, but i need something much sooner. Any ideas? Thanks for all your input folks!
    http://www.hanelineproducts.com/sho...ngine-turned-dash-insert-by-haneline-products
