56 Ford engine swap
Discussion in 'The Hokey Ass Message Board' started by 1jim, Apr 18, 2012.
  1. sunbeam
    sunbeam
    Sage Youngblutt likes this.
  2. Sage Youngblutt
    Sage Youngblutt
    haha those mounts do look like they would do the trick.
    I mocked up some wood blocks last night and think that I can shim the engine up to the top bolt hole by machining out a 1/2 inch plate that will go between the mounts and the engine block. I'll design it to have 3 grab locations for the block as well instead of just the two. Seems like it should work right?
  3. You got the wrong mounts. a 55 and 56 mount has two studs on it. I pictured a really old 153.JPG 154.JPG 155.JPG 156.JPG original 56 mount for ya.
  4. Sage Youngblutt
    Sage Youngblutt
  5. Yes that's the correct mount. you can also make a 1/4 inch spacer to fit between the block and mounts and raise the engine a bit.
  6. Sage Youngblutt
    Sage Youngblutt
    Perfect, thank ya sir!
