Technical 56 Ford F-350 drop axle
Discussion in 'Traditional Hot Rods' started by Bungi, Aug 22, 2019.
Tags:
  1. Bungi
    Bungi
    Greetings...
    I recently drug home a 1956 F350 so my son can build a F100 pickup. My question is would the drop axle be usable for a slammed Model A hot rod I’m collecting parts for?
    It has 6 bolt wheels and hubs and I was wondering if standard F100 hubs and brakes would fit the current spindles?
    Also would my 36 wire wheels bolt onto the 5 on 5-1/2 pattern or are spacers needed?
    Thanks
    Rick
    Wisconsin
  2. Boneyard51
    Boneyard51
    That axle would definitely be strong enough. Your Wire wheels , if Ford, will fit the 5on 5 1/2 hubs. Can’t help you on the conversion from 1 ton to half ton.
    Bones
  3. deathrowdave
    deathrowdave
    from NKy
    I have into this one other time many years ago . Seems to me the king pin is the same spindle swap and good to go . I just can’t fully remember .
