Hot Rods 56 Ford F100 seat riser
Discussion in 'The Hokey Ass Message Board' started by ahshoe, Feb 22, 2018.
  1. ahshoe
    ahshoe
    Bought a 56 F100 and it is mostly apart.I got what looks like 1 bench seat riser that also is an adjustable slide. Only got one. Question would this truck bench seat have separate slide risers or is this part I got with the truck off something else. Picture attached
  2. Buckster
    Buckster
    Should be another piece for the other side & a rod that went over to that side. At least that is what was on my truck's seat.
  3. ahshoe
    ahshoe
    I thought so .I need those 2 parts...I will put a wanted ad together later....Can u tell which side I have pictured?
  4. That is the Driver side glide. Notice the release lever on it. There is also a cross shaft with a quarter size gear on each end that ties them together.
    The Wizzard
  5. If you got the seat bottom go look at it. The other side may still be bolted to it.
  6. ahshoe
    ahshoe
    Nope it is not attached seat was laying flat on the flood boards and the riser was loose in a box of parts
