56 Ford ignition switch.
Discussion in 'The Hokey Ass Message Board' started by 36 Penny Coupe, Mar 7, 2017.
  1. 36 Penny Coupe
    36 Penny Coupe
    from VA
    My 36 Ford has may parts from a donor 56-57 Ford used when it was built in the early 60's. Can anyone tell me how to remove the switch shown in these pics? I need to access the wires and would be much easier if removed. It has a large spring behind it and maybe a clip of some kind ? Please advise if anyone out there knows. It is not working and needs new wires running to it. Thank you ![​IMG][​IMG][​IMG]
  2. RmK57
    RmK57
    You push the switch out from the rear of the dash and then unthread the bezel from the front.
  3. 36 Penny Coupe
    36 Penny Coupe
    from VA
    Thank you. Seems simple but I didn't want to break it Always nice to get info.
  4. Jimmy2car
    Jimmy2car
    from No. Cal
    First, remove the key.
    Next, there is a tool to remove the bezel
    Once removed, switch can be pushed to the rear & out
  5. RmK57
    RmK57
    There is no special tool. Press in the switch body from the rear of the panel. Rotate the bezel 1/4 of a turn counter clockwise, then remove the switch from the rear of the panel.
    The headlight switch is the one where you need the slotted tool to remove the bezel.
    302GMC likes this.
  6. okiewelder
    okiewelder
    from central Ok
    On my 62 you turn it to the acc side and put a paper clip in the little hole and then the key switch will rotate out.
    Then you go from behind and push and turn. I can not tell if your key switch has a hole or not
  7. okiedokie
    okiedokie
    from Ok
    I believe jimmy2car is correct, there is a special tool. That doesn't mean there is no other way. The tools are readily available.
  8. mikhett
    mikhett
    from jackson nj
    What OKIEWELDER said.I have a 56 Victoria and no special tool required.
  9. Jimmy2car
    Jimmy2car
    from No. Cal
    I also have a 56 & needed the tool. That's my experience.
    Not trying to make an argument about it.
  10. jimmy six
    jimmy six
    I bought and used the tool when I replaced my switch. On the headlight switch you press a little deal on the top to pull out the stem and use the same bezel tool to remove it too. Good luck.
