Customs 56 Ford Mainline hub interchange?
Discussion in 'The Hokey Ass Message Board' started by Domino, Feb 12, 2017.
  1. Domino
    Domino
    What all years will interchange as far as the front drum/hub goes on a 56 Ford Mainline? I am going Saturday to pick one up and it is missing a drum. Any help is greatly appreciated.
    Sent from my SM-G925T using Tapatalk
  2. metalman
    metalman
    According to my Hollanders 55/ 56 passenger, sedan delivery and Thunderbird only. That's not a lot of options, good luck with the hunt.
  3. Domino
    Domino
    Well poo. That does help. Thank you very much. I want to keep this car stock, so I will have to find one.
  4. vtx1800
    vtx1800
  5. Domino
    Domino
    The hub is the issue. I have a Galaxie parts car and it uses the same bearings. I may see if I can use it.
  6. junkyardjeff
    junkyardjeff
    If you were closer I can get a bunch of them at a couple old junkyards.
  7. Domino
    Domino
    I am going to pick it up this weekend. It is rough, but it is mine. Jeff, I wish I were closer. Brakes are my first priority.
  8. Domino
    Domino
    I am having an awful time finding one. All I get is that I should swap to disk. Not on this car. Keeping drums, keeping 14" wheels.
  9. finn
    finn
    55 Fords came with 15" wheels only.
    14 inch wheels arrived with the new 1957 design.
  10. Domino
    Domino
    So my 56 should have 15s? I will have to look closer.
  11. man there's got to be a bad drum sitting around that has a good hub ?.....somewhere bump.....
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    A 1980 Jeep Cherokee uses the same shoes as your Ford and has the same 5 on 4 1/2' bolt pattern the drum part number is a CENTRIC 12363021 see if NAPA can cross ref it and bring the one you have to compare. They run $32.79 at rockauto.com
  13. Domino
    Domino
  14. scotts52
    scotts52
    Is it home yet? Looking forward to seeing pictures.
  15. Domino
    Domino
    It is home. It is super rusty. It will need a lot of sheetmetal work. The driver's side door and the hood may be unfixable. After it is all said and done I have $150 in this car. If anyone knows where a door and hood are let me know. [​IMG][​IMG][​IMG][​IMG][​IMG]
  16. scotts52
    scotts52
    Certainly is rusty and crusty but the price was right. I sure wouldn't mind having me a 55 or 56 Ford.
  17. Domino
    Domino
    I am going to start a build thread on it. The car is complete with the exception of the front drum, rear seat bottom and radiator.
  18. scotts52
    scotts52
    Please post a link to your build thread so we can follow along.
  19. JeffB2
    JeffB2
    from Phoenix,AZ
    Try www.owenssalvage.com they are a H.A.M.B. Alliance member and are recommended on several Ford forums.
  20. JeffB2
    JeffB2
    from Phoenix,AZ
  21. Domino
    Domino
    Thank you both. Those are both good resources.
  22. 55KustomMainline
    55KustomMainline
    I may have what you need - when i get home from work I'll shoot ya some pics!
  23. Domino
    Domino
    Sounds good. Let me know.
  24. Domino
    Domino
    I have a couple hubs and drums coming. One piece less to search for!
