Technical '56 Ford radio antenna question
Discussion in 'Traditional Customs' started by crapgame, Mar 2, 2025.
  1. crapgame
    crapgame
    I’m hoping someone can tell me whether it’s possible to disconnect the cable of a stock ’56 Fairlane radio antenna from the antenna itself and, if so, how to do it. I’m trying to replace the goofy stock antenna on my ’56 with a new fully retractable antenna and would like to use the existing cable to avoid having to run a new cable all the way to the back of the radio. The car has a modern vintage-look radio that I ***ume accepts a co-ax cable plug, but an AC unit is blocking me from getting to the back of the radio to see how the antenna cable is connected. I’d really like to set up a new antenna without having to drop the AC unit, run a new cable or splice a new cable onto the existing stock wire. Yeah, I know I'm being lazy, but work smart, not hard, right? Any thoughts or suggestions would be appreciated. #146.jpg
  2. Oneball
    Oneball
    As you say an aerial cable is just a coaxial, surely you can cut it and add a plug.
  3. IIRC, the OEM antennae does unplug from the cable. Again, IIRC the cable has a female plug and to remove it grip it with some pliers and twist while pulling on it. Whether that plug will fit a different unit is hard to say...
  4. crapgame
    crapgame
    Yes, that certainly should be do-able. I'm looking for the best -- read that, "easiest" -- way to complete this project. I started with zero information about the OEM antenna but comments on this and other forums have been very helpful and I think I'm now on my way.
  5. crapgame
    crapgame
    Thanks Crazy Steve. That's very helpful. I thought the plug might be a screw-in and tried to remove it that way, but now that I know it's a push-in I'm sure I can get it free.
  6. jaracer
    jaracer
    I really do not think the coax unplugs at the stock antenna, but the antenna in your picture looks like a replacement. In that case, it might.
  7. abe lugo
    abe lugo
  8. crapgame
    crapgame
    Thanks Abe. I already have one ordered. I don't think running the new cable through the firewall will be terribly difficult. Detaching the old one from the back of the radio and connecting the new one there looks like the hard part.
  9. orangedog
    orangedog
    I installed a under dash a/c unit in my 54, your write it block access to the radio from below. I haven't installed my glove box since I did the a/c. With the glove box out I can get to the radio that way, unplugging the antenna is doable.
  10. crapgame
    crapgame
    Thanks orangedog. Removing the glove box is also a thought I had. As usual, however, I have no idea how to do that, so I'd probably have to show my ignorance by starting another string on H.A.M.B.!
  11. abe lugo
    abe lugo
    Glovebox removal is about 4-6 screw and it drops out the back but sometimes it's quicker in from the front. Also if it's old it might break and rip to bits. So check to see if replacement are a single before doing that or save you old one for a pattern.
  12. abe lugo
    abe lugo
  13. crapgame
    crapgame
    Thank you to all who helped me with this project by answering my questions.
    For those of you with any remaining interest:
    The project is complete and the new antenna, when collapsed, makes the car look much cleaner, IMO.. See photo.
    The cable does disconnect from the stock Ford antenna by pulling on the cable end with pliers. It's a simple push-in connector with no threads.
    I was able to solve my problem with access to the back of the radio by enlisting the help of my friend, who has narrow hands and long fingers. I pointed out where the cable plugged into the radio, he reached in and pulled it free. Done deal. Same in reverse for installing the cable from the new antenna.
    Only hitch was that the adjustable platform on the new antenna that sits inside the fender was just slightly larger than the mounting hole in the fender and kept pulling through when I tightened the ***embly. We fashioned a washer out of thin sheet metal and it kept the platform from pulling through. Everything is now snug and functional.
    abe lugo and TrailerTrashToo like this.
