1952-59 Ford 56 ford tail light conversion to LED
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, Jan 26, 2021.
  1. 56FORD390
    56FORD390
    Has anyone used a string of LED's to encircle the stock tail light inside the lens?
    Or, what LED's can be used?
    Thanks.
  2. Dos Cincos
    Dos Cincos
    nosford and jimmy six like this.
  3. fordsbyjay
    fordsbyjay
    from Lafayette
    I just used led bulbs from Amazon and they are super bright and don't show individual leds as they work like a regular bulb. I actually put them in my Galaxie because my 56 isn't finished. Make sure and buy red led's as the white is so bright it will bleach out some lenses and they look orange.
    Dos Cincos, JeffB2 and nosford like this.
  4. Black Wagoon
    Black Wagoon
    No reason u can't run a LED ribbon in a circle, cross, or whatever. Just make sure visibilty from rear meets local laws and common sense.
    Use Red LEDs. White LEDs show every flaw and crack in Lens, gasket, etc.
    I've seen sequential leds (from center out, kida like a flower/firework) on a Thunderbird site for ~$500
  5. Paul2748
    Paul2748
    I got a set of those bulb shown above for my 54 Ford. Great difference
  6. the-stig
    the-stig
  7. Dos Cincos
    Dos Cincos
    I used the United Pacific flashers - 90650 and also had to get the adapters which reverses the polarity to make it work with my aftermarket fuse panel. I have emergency flashers installed in mine as well so I needed two flashers. Otherwise you only need one.
