1952-59 Ford 56 ford wagon part?
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, May 4, 2021.
  1. 56FORD390
    56FORD390
    I am at a loss to figure out where this piece that is on the table came off my wagon, if it actually did.
    Can someone please give me a clue.
  2. 50sboy
    50sboy
    Between the rear bumper and the body
    jimmy six likes this.
  3. jimmy six
    jimmy six
    Should have a 1/16” thick 1” wide rubber strip stapled to it.
  4. 56FORD390
    56FORD390
    thank you. I do not have the rubber. Is it available? all the rubber stuff for mine is dried out and crumbling. How are the staples reinstalled? are they also available?
  5. 56longroof
    56longroof
    Dennis Carpenter has the tailgate and other pieces specific to wagons. They dont have the quarter window weather stripping yet though.
  6. 56FORD390
    56FORD390
    I found the window weatherstripping at steel produces. Since I have a 2 door, the windows are long. They have a 120" strip available but it is not cataloged. The issue is shipping straight pieces limited to 96". But, they coil the 120" one and it unwinds and fits in nicely. I can dig out a part number is necessary.
  7. jimmy six
    jimmy six
    Mine came from Mc Master-Carr. I saved as many of the staples as I could but made the rest from the same diameter wire. Close to a paper clip as I remember. Held them in with old fashion pliers and rolled each end with the tip of needle nose pliers. Easier to roll to the outside than inside. Poked the holes in the rubber with an ice pick to match the ones the factory stamped in.
    I did the windows whiskers the same way...good luck.
  8. 50sboy
    50sboy
    When you find that part number please let me know..
