'56 Ford Wiring Mess...
Discussion in 'The Hokey Ass Message Board' started by '56LongRoof, Aug 30, 2012.
  1. '56LongRoof
    '56LongRoof
    from Nor-Cal
    So what the hell is this? Its a little white box (more of a rectangle really) mounted on the firewall with two leads hooked to the top terminal (one going to a POS after market amp gauge and one from switched power) and one wire from the lower terminal going to the coil. I know enough to know this is the switched power to the coil but whats up with the box? I dont have an amp meter to check the amps but when I use my test light with the key on the top terminal shines bright and the lower is dim and the box gets hotter then hell... Does this drop the voltage down to 6V for the coil? Sorry if this is a stupid question... Tried to post a picture but couldn't, anyways I think you get the idea...
  2. davidbistolas
    davidbistolas
    sounds like a bomb. pissed anybody off?
  3. Orange Crate
    Orange Crate
    It is the ignition resistor, used before coils had a built in resistor.
  4. '56LongRoof
    '56LongRoof
    from Nor-Cal
    Sorry for the double post, I got an error message after I submitted the first one so hit post again and it did it twice...
  5. Orange Crate
    Orange Crate
  6. Orange Crate
    Orange Crate
  7. '56LongRoof
    '56LongRoof
    from Nor-Cal
    So is it something I can do away with if I get a new coil?
  8. '56LongRoof
    '56LongRoof
    from Nor-Cal
    Looks like I'm not the only one having problems with multiple posts today..
  9. 55 dude
    55 dude
  10. 55 dude
    55 dude
  11. d2_willys
    d2_willys
    from Kansas
    Sounds like one of them there voltage reducers that are ceramic with resistive wire in it.
  12. d2_willys
    d2_willys
    from Kansas
    Sounds like one of them there voltage reducers that are ceramic with resistive wire in it..
