1952-59 Ford 56 Front Parking Brake Cable ID
Discussion in 'Off Topic Hot Rods & Customs' started by mjlangley, Feb 23, 2022.
  1. mjlangley
    mjlangley
    from SE MI
    Hey All,
    I broke my front brake cable (runs from the handle through the firewall and down to the equalizer at the frame crossmember) and ordered a replacement from Obsolete & Cl***ic.
    They list B5A-2853-A as the correct P/N, the part I got doesn't have any ID on it, nor the bag. This cable has balls on both ends and is ~55" long.
    The cable that was on the car has a ball at the handle end and a threaded stud at the equalizer end, and is ~51" long.
    It looks like the ball/ threaded stud, 51" cable is original to the car but who knows.
    Can anybody comment on what their car has? Mine is a 2 dr. sedan, and I know from my first conversation with O&C and from their catalog that the Sunliner/Convertible is different, they measured one and its a ball/ threaded stud that's ~63" long.
    If nobody has a cable handy I'll have to see if O&C has one similar to the one I broke from another application.
    Thanks!
    -Matt
  2. okiedokie
    okiedokie
    from Ok
    Can’t tell you the length but my 55 Sunliner has threaded end under the car.
  3. mjlangley
    mjlangley
    from SE MI
  4. Paul2748
    Paul2748
    With a ball on each end, sounds like the rear cable, not the front. The number seems right for the front, probably mislabeled
    jimmy six and nosford like this.
  5. mjlangley
    mjlangley
    from SE MI
    I ended up getting another cable, PN AB-2853-D, which O&C has listed for 52-54 Fords. ~53" long, ball at one end stud at the other...
