1952-59 Ford 56 Mercury e brake / parking brake cable
Discussion in 'Off Topic Hot Rods & Customs' started by tcoupekyle, Jun 24, 2024.
  1. tcoupekyle
    tcoupekyle
    I broke my e brake cable yesterday. Any advice on a new one before I buy something and get disappointed.
  2. Alan Freeman
    Alan Freeman
    Front or rear cable???
  3. tcoupekyle
    tcoupekyle
  4. Alan Freeman
    Alan Freeman
    Concours Parts has a replacement type front cable available Part # B5A-2853-D for $34.95.
  5. bobss396
    bobss396
    I hope it goes easier than the one on my car. It was real tight by the firewall to get the cotter pin in place. I'm just glad that these parts are available. My old one was frozen solid.
  6. jimmy six
    jimmy six
    The upper clip/pin at the firewall was not there on mine but the one at the other end under the car was. It keeps the outer sheath from moving. Mine also did not have an outer plastic cover; I taped it and used heat shrink on the ends. I found out later there are ones with plastic covers.
    Make sure you have a really good ground from the body on your car to the frame. I heard from an old time auto mechanic instructor that the e brake cable cab act as a ground and start fraying.
    The trick to getting the upper cable ball out of the pull handle is to turn and push in on it…good luck.
    down-the-road likes this.
