1952-59 Ford 56 Mercury first drive
Discussion in 'Off Topic Hot Rods & Customs' started by tcoupekyle, Nov 5, 2023.
  1. tcoupekyle
    tcoupekyle
    IMG_0531.jpeg Drove my Mercury today after I finished up the build, most here probably seen it in the other post. But I noticed it was kinda long and wanted to say thanks for all the help from this group on getting it together and basically finished up.
  2. okiedokie
    okiedokie
    from Ok
    Great job. Congrats on a first drive.
    tcoupekyle likes this.
  3. tcoupekyle
    tcoupekyle
    Thank you sir!
  4. Slicks
    Slicks
    from denison tx
    Looks great !
  5. tcoupekyle
    tcoupekyle
    I appreciate that.
  6. ffr1222k
    ffr1222k
    You did a nice job!
    Enjoyed following along as you built it.
  7. 56longroof
    56longroof
  8. tcoupekyle
    tcoupekyle
    I’m glad you liked it. I had allot of fun. I thought about trying to be more in depth but I get in like a hurry sometimes.
    thanks alot long roof
    56longroof likes this.
  9. tcoupekyle
    tcoupekyle
    Reporting back that it seems to run a little hot. I think my 60s sw gauge reads a little hotter than it is but I also think the 90 dollar radiator and fan from eBay just ain’t gonna be prudent in this juncture.
  10. jimmy six
    jimmy six
    Get an electronic temp gun before you do anything; check the top on the fitting (metal) where the coolant enter the radiator and the bottom on the metal of the suction. You need to see a difference. I’ve heard 10*. I personally do not like aluminum but they are in millions of cars. If it doesn’t have a shroud, one is easy to make from a kit made by Summit for Circle Track cars.
  11. tcoupekyle
    tcoupekyle
    I will check that tomorrow for sure. I did use my infrared temp gun all over and it read 185-190 just about everywhere I checked and the gauge showed 200. It’s a very old gauge so I wasn’t exactly shocked. I will check that difference tomorrow.
    You know I had another 55 ford once with a br*** radiator and it never got warm. So you may have a point on br***.
    jimmy six likes this.
  12. the-stig
    the-stig
    If the gauge does read hot when the engine isn't hot, you can put a resistor in-line to correct it. I had to do that with my S/W gauges and eventually got rid of them, the quality just isn't what it used to be.
  13. tcoupekyle
    tcoupekyle
    Gauge is mechanical and it probably 50 years old. It’s sender is located in the water neck
  14. jimmy six
    jimmy six
    Most of the problems today are with Yblocks not moving any water thru the radiator at idle which makes the if hard to correct in traffic which is easily fixed with a smaller pulley from a 289/302.
    Later engines in our cars should not have a concern based on how small stock radiators were in early SBF’s in Falcons/Mustangs/etc. I can only blame the gasoline formulation today because it’s the only thing different.
    I will say for me a shroud helps because our cars never had them. Good luck.
  15. tcoupekyle
    tcoupekyle
    I agree it’sa 302 I have never had much issue with heating a 302
  16. mikhett
    mikhett
    from jackson nj
  17. mikhett
    mikhett
    from jackson nj
    Looks Good,Kyle ! I hope my 56 comes out as good!
  18. Dos Cincos
    Dos Cincos
    I chased an over heating issue in mine for several months. I kept finding ferrous material stuck in the ripples in the top of the radiator that prevented the water flow through the radiator. Turns out I had an air pocket somewhere in the cooling system that took forever to burp out. The ferrous material was rust from the air pocket. Would break loose when the thermostat would open.
  19. tcoupekyle
    tcoupekyle
    How’d you get it to burp out?
  20. Dos Cincos
    Dos Cincos
    Wound up backing down my sloped driveway so the radiator was the highest point. I opened the radiator cap, started the car and got it up to temperature and allowed the thermostat to open. It eventually burped out.
    orangedog likes this.
  21. tcoupekyle
    tcoupekyle
    So I drove on the freeway. 2000rpm at 60 lol 4.56 gears in their rear have got to go. But it ran at 150 so I notice it just don’t like traffic. Wonder if a nicer fan would fix the issue.
    but my wife washed it and cleaned the interior and I built a shift knob.
  22. Dos Cincos
    Dos Cincos
    Try adding a shroud if it doesn't like traffic
  23. tcoupekyle
    tcoupekyle
    It’s electric and has an aluminum shroud already. cheap Chinese 14” fan though.
  24. Paul2748
    Paul2748
    Try a wide mouth thermostat like the NAPA THM6
  25. Dos Cincos
    Dos Cincos
    And let's not forget to talk about that shift knob. How did you make that?
  26. tcoupekyle
    tcoupekyle
    ffr1222k likes this.
  27. tcoupekyle
    tcoupekyle
    I thought the face was just a little too much.
  28. ffr1222k
    ffr1222k
    It all looks good.
  29. tcoupekyle
    tcoupekyle
    So, today I got a nice SPAL fan and fired up the car waited until it reached 200 degrees and plugged in the fan relay. It sat idling and ended up cooling down to 140* and the fan shutoff. We then drove around a little bit and it maintained about 180.
    I have a 180* fan on 140* off temperature switch in the intake.
    160* thermostat
    so all in all I think the overheating issue is fixed.
    these cheap Chinese fans really are that cheap Chinese junk. The SPAL is like 100x more air flowing. Granted the spal was allot more expensive but cheaper than a motor.
    Texas57 likes this.
  30. orangedog
    orangedog
    Great to hear, now go cruising.
