56 olds rear end questions
Discussion in 'The Hokey Ass Message Board' started by 56oldssuper88, Mar 8, 2010.
  1. 56oldssuper88
    56oldssuper88
    Im wandering what rear ends will fit in this car easily. Its a 56 olds super 88.
  2. bobwop
    bobwop
    from Arley, AL
    how about a stock replacement? They are good stuff.
  3. A 57 Olds bolts in and is about 30% stronger.....parts are still available. Lotsa gear choices too
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    In the order above would be my first choice. Tri-five chevy is a bolt in also i believe. Might be Cheiftan that im thinking of.
  5. 56oldssuper88
    56oldssuper88
    So a tri five chevy will bolt in?
    Im looking for something to put a higher ratio gear set in.
  6. 56oldssuper88
    56oldssuper88
    What gear choices do i have with a stock replacement? and where do i get one? are they expensive?
  7. 56oldssuper88
    56oldssuper88
    What info can you give me on a 57 olds rear?
  8. CheapCat
    CheapCat
    from Illinois
  9. DualQuad55
    DualQuad55
    from NH
    What ratio do you have now? Common gears were 3.32:1. Gears from 48-56 will all work but you may have to use different pinion bearings for the earlier gears.
  10. 56oldssuper88
    56oldssuper88
    Thanks anyone got info about easy rear end swaps for the 56.
  11. 56oldssuper88
    56oldssuper88
    I belive its 3.42 gears. I looked the stamp number up in my book. the number was 8 on the housing correct me if im wrong about the ratio for that number.
  12. DualQuad55
    DualQuad55
    from NH
    Cheaper to set up gears than do a whole rear no? 55-57 Chevy should bolt in, 57 olds/pont should bolt in. Might be able to use early Camaro rears as well. I think the pad spacing is the same or very close.
  13. 56oldssuper88
    56oldssuper88
    Cool the camaro rear may be easier to get a hold of and find parts for am i right?
  14. 56oldssuper88
    56oldssuper88
    how hard would it be to find gears fo my rear end?
  15. 56oldssuper88
    56oldssuper88
    About the camaro rear option. Would i have to do any modifications?
  16. DualQuad55
    DualQuad55
    from NH
    measure the distance of the spring pads. make sure the shock mounts are im the same locations. the wheel bolt pattern will be different. yours is 5 on 5"chevy is 5 on 4 3/4".
    you will also likely need a conversion ujoint as yours should have a flange type.
