56 oldsmobile brake help
Discussion in 'The Hokey Ass Message Board' started by metalix_421, Aug 2, 2011.
  1. metalix_421
    metalix_421
    so im trying to order a brake overhaul kit for my 56 rocket 88 but kanter offers (Deluxe Brake Overhaul Kit 53 - 59 Oldsmobile Full Size Bendix power brakes)and
    (Deluxe Brake Overhaul Kit 53 - 59 Oldsmobile Full Size Delco-Moraine power brakes)
    which one will it be/ how can I find out.
  2. Darkharts
    Darkharts
    from Corona
    It's based on your booster- if i remember right their is two different types of power boosters. look up the catalogs and see if you can match yours to a pic. the bendex should be the tredelvac. Each booster used it's own master cylinder, which is why you have two options.
    good luck
  3. flatoz
    flatoz
    theres clear pictures in my '55 olds workshop manual of each of the tredelvac boosters and they are the same brands as your talking about bendix and moraine, there is a difference so you really need to determine which you have, they basically look the same so you need to look for the details that separate them.
  4. metalix_421
    metalix_421
    ok before I start ripping **** apart is there any way you can tell before hand? this set up is all new to me, I have either had older now power or newer ot cars. here are some picks for you olds/ smart people. may not be any help but I would like to know if at all possible before I start loosing bolts:(
  5. metalix_421
    metalix_421
    Would like to order the kit tonight if possible. Don't want to order the wrong kit thanks
  6. 2Hep
    2Hep
    Call Fusick Automotive and they can help you with the right one. From what I recall off one of my '56's is that it was a Del-Co. You will know which it is when you remove it as the iron casting will say which of the two.
    I believe that the two come from where they were built. The Olds built on the East had one brand and the others (out west and south) had the other brand of brake.
  7. 123
    123
    from Seattle
    Pull the plate that is behind the brake pedal and you will get a better view of the booster. You have to pull it anyways to do the job. The 4 nuts in the center of the plate hold the booster in place. It will just flop around once the plate is off but not enough to hurt anything.
    Warning, some of the screws might be too rusted and you will have to get creative. I used a pair of vise grips on a few of mine.
    http://cl***icoldsmobile.com lots of good olds guys over there.
    There are some pics of mine here... http://www.jalopyjournal.com/forum/showthread.php?t=595288
    From what I have read about TreadleVac systems I will be removing it before this car sees the street again! I already have the Scarebird brackets.
  8. metalix_421
    metalix_421
    thanks for the help guys. made the order this morning from kanter. and from what they say you can tell what brakes are on it by what color the can that the master cylinder is in. silver/gray is the Delco-Moraine brakes. I guess we will see when it gets here if it all fits.
