56 plymouth frames
Discussion in 'The Hokey Ass Message Board' started by grumpyweasel, Feb 27, 2013.
  1. grumpyweasel
    grumpyweasel
    from Colfax, WA
    I have a 56 plymouth 2 door hardtop and the frame is bend. My question is: are all 56 frames the same? Since I a going to do a frame off restoration anyway, I thought I could prep another straight frame and be ready to go. Thanks for helping!
  2. 73RR
    73RR
    Unless the frame is really bad then any competent frame shop can fix it. Look for an old timey shop that actually knows what a frame looks like...
  3. flatford39
    flatford39
    Cars from that era typically had different frames for convertibles than the rest of the line. Like 73RR says above a good frame shop could probably bring yours back to spec.
  4. stillrunners
    stillrunners
    from dallas
    my 56 hardtop Fury is sitting on a 4 door frame....every mount is there....my Fury frame had a 354 hemi and auto trans welded into it when I got it and was not very nice job....and since the Fury was a three on the tree factory car I had a nice donor frame with the standard mounts where they should be...lined the frames up side by side and all match up....I was working the floors on the Fury at the time....wished I'd would have keep the Fury frame instead of stripping it down....was a long time ago....
  5. MoparFinman
    MoparFinman
    from Okla
    I can't seem to get the frame scan that I have to load. If you you would like I will e-mail it to you.
  6. oldolds
    oldolds
    55-56 Plymouth. Hollander # 30, 31. Change crossmember to fit trans. There are a few other change, brackets ect. It appears that conv. takes the same frame on this one.
  7. plodge55aqua
    plodge55aqua
    from Alberta
    Those 56 Plymouth Frames are all the same.. The only thing that changes is the Is the 6 to 8 Motor Mount pads and Shifter Mount pin on the inside of the frame. The Trans Mount crossmember is the same in the same location for a 6 or 8.
  8. grumpyweasel
    grumpyweasel
    from Colfax, WA
    You guys are awesome! What a bunch of knowledge out there. Thanks
  9. MoparFinman
    MoparFinman
    from Okla
    I changed format hope this helps.
