56 Pontiac Intake gasket question
Discussion in 'The Hokey Ass Message Board' started by wvenfield, Sep 18, 2008.
  1. wvenfield
    wvenfield
    I need intake gaskets. Nobody I've found list gaskets for a 56. They have to be the same as......?
    I found a Cal Custom set that I bought but they are way too thick. My car has a 4 barrel intake which shouldn't matter but from what I understand the intakes are basically all the same up to 65?
    The later sets are one piece where the earlier ones are 2 (3 piece) with the metal center sections. I found Fel-Pro list them for a 58 but not a 56. I would think they would know that they would interchange but............
    They would have to be the correct thickness as they use the very thin center metal sections.
    Yes? No? I just don't want to order to get the wrong thing.
  2. axle
    axle
    from Drag City
    Call CPR , California Pontiac Restorations in Santa Ana, California. they will have your 55-60 gaskets.
  3. DE SOTO
    DE SOTO
    Axle is right, CPR Has all kinds of *****en **** for early Pontiac's.
    The '58 gaskets you speak of should work, I have bought those for my '60 before.. The ports my a bit larger but i would think it won't matter.
    Then again, I havent tried.. But i would if i had an early Pontiac.
  4. 53chevy
    53chevy
    Well, I'm new to Pontiac's and did allot of research. the bolt patter is the same thru '64 (I believe 64 was a transition year, as some had the changes updated, which you would see on the '65 models). But the forward water p***ages are different. 61-64 have two round holes. My '60 (I would say the same for '59 too) had an L shape p***age. Also may be different, is the exhaust crossover for the choke. I slapped a 61-64 Weiand intake on my '60 389, made the changes to match the water p***age (Plugged the forward p***age, re-shaped the other, which was done by Williams Machine shop here in Ventura, I just smoothed it out) and the bosses for the Coil and kick down brackets. Best bet is take your intake in and match to the 58, the bolt and exhaust ports should match, not sure about the water p***age and crossover. Good Luck. there's a thread somewhere that has good info on Pontiac's, I'll see if I can track it down.
    Ken
  5. Pontiacres Ranch
    Pontiacres Ranch
    As I remember I couldnt get Valve Cover gaskets from Napa. Brake Shoes either, but Auto Zone had those & the rebuild kits for the wheel cylinders. Thats why I ended up Putting the 70 Pontiac 350 in mine. I may have a set of NOS Intake gaskets, remember getting a set with the Car. Ill Dig & let you know.
  6. wvenfield
    wvenfield
    Thanks so far. I'll look up CPR. 53Chevy I'd love to take the intake over and match up the gaskets but nobody has any of them around here.
  7. 53chevy
    53chevy
    Yeah, it's not light (hahaha!). CPR is good and you have AMES too. NAPA has been pretty good on the parts. I've been tracking down NOS for my engine for use and back-up stash. I think Offenhauser sells gaskets too, look into them to, maybe.
    Ken
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Replacement intake gaskets for early Pontiac V8s use one part number for '55-'60. If you can't find any, I'm sure I've got some old Mr. Gasket sets.
  9. Pontiacres Ranch
    Pontiacres Ranch
    Sorry, Must have offed them. Ive got the motor & trans under the bench along with other odds & ends though.
  10. billbrown
    billbrown
    56 abd 58 are the same according to the parts interchange I have at athe Pontiac Dealership I work at that Im looking at right now. Im so helpful.
  11. wvenfield
    wvenfield
    THANKS!! $23 for 56 Gaskets at CPR. 58 Gaskets at Fel-Pro are $13 dollars.
    That's a 12 packs worth of difference!!
  12. d2_willys
    d2_willys
    from Kansas
    I'm sure Kanter has them too.
  13. 55-60 is one intake pattern, 61-64 differs slightly. 59-60 4bbl intakes take an AFB, a '56 4bbl intake only takes a 4GC from the looks of it. It's been too long since I took the intake off the car.
  14. poncho catalina
    poncho catalina
    from summit il
    Pontiacres Ranch
    sent you an e-mail about mounting a newer motor in a 56
    poncho
  15. wvenfield
    wvenfield
    Thanks. I'll check PAR out for parts. Seems Fel-Pro don't actually have them in stock. I havent got around to ordering them as I have alot of other work to do also.
    I'm not at home but when I get there I'll check out your email but I'm kind of partial to the 56 engine.
  16. poncho catalina
    poncho catalina
    from summit il
    wvenfield
    Sorry I did not mean to jump on you thread. I was looking to get some info from pontiacres ranch. you have to rember I'm a fng
  17. wvenfield
    wvenfield
    I see. LOL I have a head cold and not real clear right now either. :D
