1952-59 Ford 56 Ranch Wagon refresh
Discussion in 'Off Topic Hot Rods & Customs' started by 56longroof, Mar 18, 2016.
  1. 56longroof
    56longroof
    Been meaning to do this for a while. I bought my wagon via the Internet from a POS used car salesman a little over a year ago. After a lot of thought I decided to pull the poor running 6 cylinder and put in a 292 that I had earmarked for my 61 Unibody. Well, what was supposed to be a quick engine swap evolved into a lot more. After I pulled the engine I found this. 20151107_161443.jpg 20151107_161512.jpg So I cut out the offending area 20151122_120946.jpg 20151122_121003.jpg Weld in new and paint 20160103_160444.jpg 20160103_160503.jpg More to come......
  2. 56longroof
    56longroof
    The front suspension on my wagon was also in need of some love. I could move the steering wheel back and forth 2-3" while driving and the car would not move. I decided to pull everything and either rebuild it or replace it. 20150906_173147.jpg 20150906_173130.jpg After I pulled everything I decided I might as well clean everything up and paint it. This was probably the worst part of the whole project. For 3 weekends I laid under the car s****ing and cleaning from front to back. After 3 weeks of cleaning I started to paint 20160124_115100.jpg
    And paint 20160124_115055.jpg 20160124_115110.jpg I pulled the rear springs also and put new bushings and anti squeak pads in. 20160130_120148.jpg Put everything back in with a rebuilt steering box by Redhead Steering Gears. I also upgraded the front with Aerostar coils with a .750 spacer and 20160228_183902.jpg 20160228_165008.jpg Versailles spindles/disc brakes and self adjusting rears. Put 2" blocks in the rear also. Replaced all the brake lines with a stainless kit from Cl***ic Tube. 20160207_171759.jpg 20160207_171720.jpg 20160207_171738.jpg 20160207_171751.jpg
  3. 56longroof
    56longroof
    Got some new Firestones and painted the wheels. 20160311_162326.jpg Picked up a nice set of 54 Chrysler wheel covers too. 20160311_170742.jpg
    Rui likes this.
  4. 54sunliner
    54sunliner
    Damn, your on the move!!!
    56longroof likes this.
  5. dodg66440
    dodg66440
    Looking good!
  6. 56longroof
    56longroof
    I've been working on it every weekend. I wanted to have it done by Easter for family pictures but ran into a couple set backs. Thanks for the complements.
  7. Mark T
    Mark T
    Looking great, what kind of paint are you using?
  8. HOTRODPRIMER
    HOTRODPRIMER
    looks good.HRP
  9. 56longroof
    56longroof
    I used Rustolem on the whole project. It laid out surprisingly well. Even the paint on the wheels is Rustolem. I decided to use that so it would be easy to touch up.
  10. voodookustoms
    voodookustoms
    Looks awesome. Those are THE tires for that car. Ive gotta get myself some firestones. Such a good look.
  11. 56longroof
    56longroof
    Thanks. I think the Firestone Deluxe Champion is probably the best looking bias out there. I think any 50's car would benefit from them.
  12. Texas57
    Texas57
    Great job...that's gonna be a sweet ride.
  13. rustyfords
    rustyfords
    from Conroe, TX
    Looks really nice. A lot of work, but it's worth it.
  14. 56longroof
    56longroof
    This is how it sits now. 20160312_195219.jpg Going to put some time in today on it. The T85 od I put in it is a lot longer than the T86 od that it had. I'm not sure how the Trans mount was from the factory but the cross member in my car is about 4-5 inches too far forward. So I'm going to fab one up. I also need to relocate the radiator. I have no clearance for the fan. Other than that I should have it ready for its first run by next weekend.
    Rui and Texas57 like this.
  15. okiedokie
    okiedokie
    from Ok
    Great job, looking very nice.
  16. mitchs66
    mitchs66
    Looking good.
  17. Jsprengeler
    Jsprengeler
    Man, that's amazing work! Now come do mine.........:D
  18. mikhett
    mikhett
    from jackson nj
    Great Job MR LR!
  19. 56longroof
    56longroof
    Bring it on down!
  20. 56longroof
    56longroof
    Didn't get much done today. Seems like every step on this project produces a problem. I put the shift linkage on today and the ends on the rods that go through the shift arms were too short. The bushings that are in the shift arms are thicker than on the T86. So I had to cut the bushings down until I could get the cotter pin in. Got the Trans mount about half done and the clutch linkage all together. That's about it. Had to cut it short so the wife could go to work and I took my daughter to the local Community Center for an Easter egg hunt. All in all a good day. Will get pics up soon.
  21. Rui
    Rui
    Great Eric.
  22. 56FORD390
    56FORD390
    I am trying to get my front suspension rebuilt but am having a lot of trouble getting the idler arm out of the frame bracket and the center link. Any help on how to do this would be appreciated.
  23. 56longroof
    56longroof
    You will have to take it all out as a unit. Once it's out screw the idler arm itself out of the "nut" in the bracket and the same for the center link. Then you can take the nuts off the center link and the idler arm bracket. When you put it all back together the nuts go on first and then screw the ldler arm on each end. It's a little awkward but not too bad. Do you have a copy of the article on how to rebuild the front ends on these cars? It was a big help for me.
  24. 56FORD390
    56FORD390
    I am trying to locate the article, but have had no luck.
  25. 56FORD390
    56FORD390
    It is a left handed thread. Now it is coming apart.
    Thanks to 56longroof point me in the right ( or left in this case ) direction.
  26. 56longroof
    56longroof
    I have a copy you can have if you want. I don't think I'll need it anymore.
  27. Mr. Tomato Head
    Mr. Tomato Head
    So much for the "quick engine swap". Yikes! Hope you make it by Easter! Dress everybody up in period-correct clothing! Looks good so far!
  28. 56longroof
    56longroof
    Yeah,it snowballed pretty quickly into a lot more. Alot of work and pain in the *** sometimes but worth it I think.
  29. bobss396
    bobss396
    Yeah, the idler arm is fun on these. I forget all the torture I endured with mine. Locked the center link in a bench vise to make it easier. I also took out anything and everything. Rusty parts went into my citric acid bath after I s****ed 1/2" of grease off them. Your black paint looks great. I used VHT rollcage & ch***is satin black, went on nicely and easy to touch up. The ch***is is painted forward from the trans cross member.
  30. 56longroof
    56longroof
    Got a little more done today. Got the carbs and choke cable done. Several little things that are not visible but needed hooked up like the starter cable,engine grounds,etc.are finished. Radiator is in place but just sitting there. Still need to drill new holes to mount it. Pretty productive day all in all. 20160324_131933.jpg 20160324_131924.jpg 20160324_131918.jpg
    bondojunkie likes this.
