1952-59 Ford 56 Vicky
Discussion in 'Off Topic Hot Rods & Customs' started by kgdb, Sep 30, 2015.
  1. okiedokie
    okiedokie
    from Ok
    I will post some pictures.
    Copper Top likes this.
  2. kgdb
    kgdb
    from The 60"s
    A little color and soon it will go back in. Tonight do the shift kit on the trans and then the trans is ready to go as well.
  3. kgdb
    kgdb
    from The 60"s
    Transmission all done and with some NOS parts. Cool.
  4. kgdb
    kgdb
    from The 60"s
    All nice and pretty now. Just need to pick up the intake gaskets and ****on that up. 20151128_223943.jpg
  5. 56longroof
    56longroof
  6. Rui
    Rui
    Agree! Its looking good.
  7. kgdb
    kgdb
    from The 60"s
    Firewall is finished, a quick prep and I will shoot some color. Get some paint on the frame and suspension parts and the motor goes back in. I look forward to the extra floor space. lol
  8. kgdb
    kgdb
    from The 60"s
    Well not a lot to report, a little color on the frame. Will order up the color for the firewall this week.
  9. 54sunliner
    54sunliner
    Looking good, keeping the drums up front?
  10. kgdb
    kgdb
    from The 60"s
    If they measure ok and can be turned then probably for now. If they are junk I may just go ahead and do the conversion now.
  11. bobss396
    bobss396
    Once I drive my car (get the engine back in 2 days...) I'll know if I want to upgrade the steering. I had a '64 with manual steering and '68 Bullit Mustang with the 390 that was manual. No problem except in tight parking spots.
    The Cavalier rack seems like a good way to go. The frame brackets will be a little bit of work.
  12. kgdb
    kgdb
    from The 60"s
    A buddy has this conversion in his shoebox and it is very good. I drove that car a few times and am very happy the way it steers/handles so I was certain I would do it on my 56. It wasnt to bad to do, I spent hours staring at it after I had the old steering all out as I wanted to make sure I took everything into consideration before I confirmed the location and started on the brackets.
  13. kgdb
    kgdb
    from The 60"s
    A little bit of color. The color I decided on is Chrysler PWG, Cool Vanilla.
      184.9 KB
      153.8 KB
      147.2 KB
  14. ffr1222k
    ffr1222k
    That color looks close to Ford's Wimbledon White in the picture.
  15. kgdb
    kgdb
    from The 60"s
    Thats what I thought as I was shooting the color......
  16. ffr1222k
    ffr1222k
    I always liked Wimbledon white.
  17. 54sunliner
    54sunliner
    Single stage? Looks very clean, now the power plant fun begins
  18. kgdb
    kgdb
    from The 60"s
    Yes, just a single stage for the firewall and inners. The body will get a base / clear. In the next few days I will get the motor and trans back in and then it will all come together and look like I have actually done something. lol
  19. HOTRODPRIMER
    HOTRODPRIMER
    Actually there is a good bit of difference in the Chrysler Cool Vanilla & Wimbledon White.
    The trim on the wagon is the Chrysler color which is a little darker and creamier. HRP
    The firewall on my Deuce pickup was Wimbledon White. HRP
  20. mikhett
    mikhett
    from jackson nj
    Your Lucky you got the PWG/XWG cool Vanilla.I ordered a gallon of single stage when I painted my 62 in my avatar and the jerk @ Finishmasters gave me GM White it certainly wasn't cool vanilla.Your car looks good Im also building a 56 Mild Kustom.Check my profile for pics.
  21. kgdb
    kgdb
    from The 60"s
    Motor and trans in
      178.9 KB
    Texas57 likes this.
  22. kgdb
    kgdb
    from The 60"s
    As I am using a steering rack, a center steer unit from a Cavalier. The next problem was how to mount the power steering pump. I am using the cavalier pump and had to swap out the pulley to a v-groove pulley and then figure out a way to mount this pump to the Clevelend motor. None of the bracket ***ortment that I had on hand even came close so I decided to fabricate one. Here is a pic of the unfinished bracket while I was trial fitting it.
  23. bobss396
    bobss396
    Any pump should work in theory, at least to my convoluted thinking. Hoses would be an issue, but not a huge one. I also make up anything that I need.
  24. 56longroof
    56longroof
  25. kgdb
    kgdb
    from The 60"s
    Not a lot of progress to report, just playing with some little little stuff. Here is where I am now, will finish up a few things while the frt end is apart and then get some color on the rad support and inners etc and start to get the frt end sheet metal back in place.........the saga continues............. :)
    Texas57 likes this.
  26. al_inbancroft
    al_inbancroft
    Great job Ron.
    how about of your steering yoke conection possibly?
    thanks.
    Al
  27. kgdb
    kgdb
    from The 60"s
    Yes for sure will get that done before the sheet metal goes back on. Just have to go to a local shop here and pick up the joints that I need. Good eye.
  28. kgdb
    kgdb
    from The 60"s
    Hi Strangers! Progress was slow over the winter as other priorities took over but slow and steady wins the race! So a small update, Brakes are finished( all juiced up with a great pedal feel), new fuel tank is in, some wiring up front done (main harness still to go), driveshaft is in, 9" all done (3.50 gears) .... overall most of the mechanical is done. Spring is in the air so soon as I can open up the door I will get back on the body. Stay tuned....
    Copper Top, Dos Cincos and Texas57 like this.
  29. ffr1222k
    ffr1222k
    It looks like it is all coming together. You are making me want a '56 Vic.
    Keep the updates coming!
  30. welderdave562
    welderdave562
