1952-59 Ford 56 wagon sending unit
Discussion in 'Off Topic Hot Rods & Customs' started by 56longroof, Oct 8, 2022.
  1. 56longroof
    56longroof
    Is anyone reproducing the fuel sending unit for wagons yet? Mine is leaking and I'm getting tired of the raw fuel smell every time I fill up.
  2. Texas57
    Texas57
    If the unit is still working, add a caulking around the flange. Make sure whatever you use is resistant to the gas when set up. Mine had the same problem a few years ago, even with a new gasket. Caulking / sealant fixed it.
    Does Tanks Inc make a unit for the wagons?
    56longroof likes this.
  3. Rustvelle SS
    Rustvelle SS
  4. 51504bat
    51504bat
    I have an Auto City Cl***ic tank in my '54 Ranch Wagon. Not sure where I got the sender. The car isn't on the road yet so I have no idea how well the gauge will work and its been converted to 12 volts. Time will tell. But the tank fit perfectly.
  5. 50sboy
    50sboy
    Another Auto City Cl***ic tank - perfect! I use a sender and adaptor ring because I have aftermarket gauges. But I did have the Stinkys from the stock vent - I plumbed it to the back of the ch***is and added a filter...
