1952-59 Ford 56 wiring diagram
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, Aug 11, 2015.
  1. 56FORD390
    56FORD390
    Is there a wiring diagram available for the ranch wagon available? I need to rewire all or most of my project.
  2. Dobie Gillis
    Dobie Gillis
    Google The Old Car Manual Project, you may find a free downloadable copy there.
  3. rick55
    rick55
    There is one available for 1957 which is the same.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    If you are doing a total re-wire and using a kit the diagram won't be a big help because they eliminate a lot of excess wiring and make it more basic. This book will be a big help: http://www.speedwaymotors.com/Book-How-To-Wire-Your-Street-Rod,2824.html If you use a one wire alternator it also saves a lot of wiring clutter,a lot of the guys here used the Rebel wire 9+3 kit. http://rebelwire.com/rebel-wire-products.php?cat=Wire Kits If you order from them tell them you are a HAMB member. If you are adding some additional upgrades be sure to add relays to your plans read this : http://www.watsons-streetworks.com/tips Click on "a current topic" one common complaint is dim headlights the stock wiring does not play nice with today's Halogen bulbs so get this: http://www.ebay.com/itm/361017529037?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
  5. Paul2748
    Paul2748
    Are you going to rewire it per factory specs or are you using a kit?
    If per factory, there should be an Electrical ***embly Manual available. Check with this guy
    Jim Osborn Reproductions 770-962-7556.
    If your using a kit, do it any way you want. The book Jeff mentioned should be a good reference.
    When doing the install, take your time and do it neatly. Don't cut and finish any wires until you have run everything so you can see how every thing lays out in case you decide to change any routing..
  6. bobss396
    bobss396
    I got the Osborn book on evilBay... like a little paperback. You have to enlarge the pages for it to be readable.
  7. HOTRODPRIMER
    HOTRODPRIMER
    If your not restoring a universal kit is the way to go and there are a lot of them out there,,some very reasonable and some get a little pricy,the more expensive kits include everything you will need.
    I used the American Auto Wire in the wagon. HRP
  8. Paul2748
    Paul2748
    I got the one for a 56 Bird and it's about 16 inches wide
  9. 56FORD390
    56FORD390
    Thank you all for the informational leads. I am not doing a restore, so one of this kits should work very well.
  10. al_inbancroft
    al_inbancroft
  11. Zapato
    Zapato
    Anyone know who prints the large poster size wiring diagrams ? Remember seeing a post awhile back (maybe in another forum) and wish I'd ordered one for each car I own. They were definitely easier to follow as they were color coded and not an old factory black on white print that practically requires a magnifying gl*** to follow.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    A lot of print shops can enlarge a letter size to bigger sizes,I had a Fed-Ex Kinkos Copy enlarge one to 11" X 14" and laminate it made it easier to read and grease proof cost was $6.
