1952-59 Ford 56 with borgenson steering box
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, Feb 12, 2018.
  1. 56FORD390
    56FORD390
    The box is in. I need to shorten the steering column and the sleeve.
    Question 1: What is the dimension from the mounting flange on the dash to the bottom of the turn signal housing?
    Question 2: What to do about the horn ****on since the wire can no longer run through the steering shaft?
  2. mnfordfan
    mnfordfan
    I cant answer your question 1, but I looked at a 57 that had the borgeson box, they had a horn ****on installed under the dash, as the factory wire cant run inside the steering shaft.
  3. green53ford
    green53ford
    from Wisconsin
    Look up save that sweet horn on the HAMB.
    Rui likes this.
  4. 56FORD390
    56FORD390
    Did you happen to notice how the column mounted to the borgenson box? Was it the stock column? I understand that after market columns do not mount in our rides.
  5. 56FORD390
    56FORD390
    OH MY. That link is exactly what I needed. Thank you green53ford so VERY much ! ! !
  6. nascardave
    nascardave
    tried to find that information but i am unable to find it. please post link
  7. 56FORD390
    56FORD390
    search "save that sweet horn" in ***les only. It came up for me that way.
  8. nascardave
    nascardave
    thanks it worked this time
  9. ffr1222k
    ffr1222k
    That was a good solution for the problem.
