Technical 57' 272 Y Block carb Idle Issues
Discussion in 'The Hokey Ass Message Board' started by Westco48, Jan 18, 2019.
  1. Westco48
    Westco48
    I have a 57 F100 with the 272 Y-Block/ manual 3 speed, when I come to a stop the engine is idling high I have to hit the pedal for it to rev down so I can put it in 1st, but when I do that the idle drops real low like to the point of almost shutting off, this is constant I have to hit the gas pedal for it to rev down...carb stamped numbers are C2AF AH which denote a Autolite 2100. PO said he rebuilt the carb.
    Any input?....thanks
    If I need to rebuild myself anybody have a good source for quality parts?
  2. AldeanFan
    AldeanFan
    Fast idle on the choke is sticking,
    I solved this on mine by changing from automatic choke to manual.
    Westco48 and loudbang like this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Or the throttle shaft is loose in its bores allowing the throttle plates to stick or the shaft is loose in the primary linkage arm , or the fast idle cam is sticking or your return spring is weak or the counter weights in the distributer are sticking or the vacuum advance is sticking .......
  4. Truck64
    Truck64
    from Ioway
    Westco48 likes this.
  5. carbking
    carbking
    Check that the choke ****erfly is vertical. If not, then the fast idle would be engaged until you kicked the throttle.
    It also sounds as if the curb idle RPM is set too low. If the carb has a separate (from the fast idle) idle setting, ALWAYS wait until the engine is at operating temperature, and the choke ****erfly is vertical (wide open) prior to setting the curb idle RPM.
    Jon.
