Just in case anyone is interested. Got a great 312 out of a '57 Ford slated for rebuild. Standard bore and standard crank. Hard to believe. All '57 stuff. ECZ-G heads, ECZ-B intake, flat top manifolds, etc. This will be one sweet Y-Block when done. Can be built with p*** car or rear sump oil pan, buyers choice. Auto now, stick flywheel is extra cost at buyers choice before balancing. Will be completely gone through, with all bearings, camshaft. lifters, oil pump, heads rebuilt with hardened seats, water pump, timing set, pistons, moly rings, balanced and blueprinted, etc, and all the required oiling system mods. Engine will be run in on a test stand when finished and ready to go. $4600, and it can be put on the lay-a-way plan.
