Hot Rods 57/59 9 inch rear
Discussion in 'The Hokey Ass Message Board' started by bangngears, Dec 13, 2023.
  1. bangngears
    bangngears
    from ofallon mo
    im having trouble finding emergency brake cables for a 57/59 ford 9 inch. In the past i used another set of cables that interchanged but since forgot. Any input appreciated.
  2. squirrel
    The end that goes into the brake should be a normal cable like used on most other old cars, with the three spring tabs on the housing, and a cylinder on the end of the cable.
    When looking for parking brake cables, I get the cables for the car it's going in, not for the rearend...but of course that only works if they have a normal end, and if you can find them. Also it helps to know what you're putting the rear end in.
    alanp561 likes this.
  3. krylon32
    krylon32
    from Nebraska
    I've done a few in the last few years and I just used the universal Lokar cables. The only problem I had with them is they're to dam expensive.
  4. alanp561
    alanp561
  5. da34guy
    da34guy
    What Krylon 32 said.
    Dirty Dingus Magee likes this.
  6. seb fontana
    seb fontana
    from ct
  7. I’ve got that axle in my 56 chevy. The stock cables work fine
    56 chevy cables that is
    lumpy 63, seb fontana and squirrel like this.
  8. 56don
    56don
    I got some for the 57 9inch in my truck from Rockauto. But thats a **** shoot.
  9. two couped up
    two couped up
    from pa.
    On my 39 coupe with a 57 9 inch, I used two left cables from a 86 f150 they fit the hole in the backing plates and I made brackets to connect them to the stock front cable from the e- brake lever. Raybestos Part # 5296-0572240 it is 60.375 inches overall in length. I can take pictures of how I mounted mine if you need them.
  10. bangngears
    bangngears
    from ofallon mo
    thanks for all the replies. ill figure it out
  11. vtx1800
    vtx1800
