57-64 olds rear?
Discussion in 'The Hokey Ass Message Board' started by lowdown and dirty, Mar 25, 2010.
  1. lowdown and dirty
    lowdown and dirty
    whats the best way to set these rears up for later (easier to find) brakes... I read that if youre narrowing to go with an econoline backing plate.. seems like a good idea. what if you arent narrowing???
  2. lowdown and dirty
    lowdown and dirty
    hahha again with the econoline... im doing it!
  3. bobwop
    bobwop
    from Arley, AL
    leave it all stock. I get all the parts I need (bearings, seals brakes) from NAPA
  4. lowdown and dirty
    lowdown and dirty
    wow really!? thats awesome... the one im getting is complete, so if its the right year (width) ill just rebuild it and roll with it.
    what about yokes... will the u-j and shaft bolt in???
  5. bobwop
    bobwop
    from Arley, AL
    I don't think it is a direct bolt in. You will need to take your yoke and shaft to a driveline shop for measurement (or do it yourself) and they will find the right cross for you.
  6. chop32
    chop32
    That explains why my splines were so short and the axles looked like they were cut off.
    I must have a Pontiac housing, its on stock spring pads in my '57 Chevy!
    Thanks for all the helpful info...
    I went with a buddy to look at some early Ford parts and saw an aluminum 3rd member on the floor. The guy said it was for a 9" Ford and I could just take it! Its a Mickey Thompson center section with 4.30 gears, but no posi (it just says Thompson so it may be an early model). Made my weekend!
  7. lowdown and dirty
    lowdown and dirty
    damn ... it turned out to be a '55... i guess ill keep shopping haha
  8. I had a '56 Pontiac peg leg in my '36 before I found the '63 Olds rearend.
    The '56 was tired and I couldnt get any parts for it any more.
    The '58-'64 is far easier to service.
  9. startgroove
    startgroove
    from Oregon
    Would one of those 59 olds rear ends be available as pumpkin only? That's all I need. Cheers, Russie.
  10. startgroove
    startgroove
    from Oregon
    Applecrate, would you be interested in parting with one of those Pontiac/Olds pumpkins? I need a 29 spine, 3.42 (or close to that) for a 57/58 axle housing. Cheers, Russie.
  11. draggin breath
    draggin breath
    I have a '61 okds rear 55 miles from you,$150 loaded. PM me if you want it.
  12. What's wrong with the rear end in your 55. It is a drop-out (pumkin) type and plenty strong enough for up to 600 horse or more? Plus, you can find gears for it up to and including 6:00's.
  13. R. Seghi
    R. Seghi
    I still have a set of axles and an open carrier ***embly with gears.
    $100 everything.
  14. stuart in mn
    stuart in mn
    The original poster hasn't been here for four years, chances are he won't see your offer. ;)
  15. rascal55
    rascal55
    57 housing will bolt right in to a 55 chevy !
    57 housing will run 150.00 to 250.00
    original posi 400 to 700 smackers.
    new after market posi aabout 700 .
    check Fabcraft or JD Race and Restoration
