Projects 57 Buick special project
Discussion in 'Traditional Customs' started by Mack0331, Jul 17, 2017.
  1. Fabber McGee
    Fabber McGee
    Okay, thanks. I'll take a look. The quality has been good, huh?
  2. philo426
    philo426
    Plus ,due to the sculpting of the body panels,it would be easy to mask off a two or three tone paint job.
  3. Chris
    Chris
    Man, you're hauling ***! Looks great, especially for a first timer!
  4. Mack0331
    Mack0331
    from Auburn WA
    It is my first time doing a full restoration on a cl***ic car but I am a ASE certified master tech so I do work on cars for a living. Most of this cl***ic stuff is new to me but a car is a car pretty much.
  5. Mack0331
    Mack0331
    from Auburn WA
    I'm doing a two tone. I actually just bought all the paint and bodywork supplies. Holy **** paint is expensive ! I did buy high end paint but damn $670 a gallon . well I'm not doing all this work to put cheap paint on so oh well only money. I've stopped keeping track of how much I'm putting into it at this point lol
    Peanut 1959 and chryslerfan55 like this.
  6. Fabber McGee
    Fabber McGee
    What colors? What are your plans for the interior? Looks like I won't have to wait years to see it.
  7. Mack0331
    Mack0331
    from Auburn WA
    colors are very close to this pic . Interior will be as close to the same colors as I can get . won't be 57 Buick original interior but will be 50's style.
  8. philo426
    philo426
    Very sharp!Sure hope the expensive paint is durable!
  9. Mack0331
    Mack0331
    from Auburn WA
    The clear coat wasn't cheap either so I sure hope so
    Got DuPont chromabase paint
    PPG 2002 clear
  10. scotts52
    scotts52
    Do you have some kind of manual that shows where everything goes or are you going off memory? I'm trying to piece together a Caballero wagon and am hoping to find exploded view diagrams.
  11. Mack0331
    Mack0331
    from Auburn WA
    I bought the factory service manual.
  12. Mack0331
    Mack0331
    from Auburn WA
    Since I'll be painting soon and don't want water messing up my expensive *** paint I built a manifold / water trap with some copper pipes. I know I didn't have to make the horizontal parts as long as I did but I bought the pipe in 10' sticks so was trying to work it out so I used it all. Close to 80' total. Put ball valves on the down pipes to drain water. Also added a devilbliss 3 stage filter / desiccant dryer to use when painting. I never soldered copper before this but it was easy and it works great no leaks. I ran it for a while with a sander and did get water out all the downpipes. Still got a good amount of water in the first little filter but compressor was running pretty hard working the sander and I didn't notice any water getting to the tool so it should do good for painting especially after running through the new dryer. I'll get a new hose for painting too.
    BigO likes this.
  13. philo426
    philo426
    Irrigation system to keep the dust down!I remember my neighbor painting a Cutl*** Supreme who hosed down his garage floor before shooting the copper paint.Came out great with no dust in the finish!
  14. Mack0331
    Mack0331
    from Auburn WA
    Yeah I'll be cleaning out the shop and wetting the floor first too.
  15. NickOc
    NickOc
    from Chicago
    Beautiful car. Love the progress, but I think you will need to flip these calipers or you will have a heck of a time bleeding the front brakes.
    Peanut 1959 likes this.
  16. Mack0331
    Mack0331
    from Auburn WA
    Yes I know about the calipers. I didn't leave it on just wanted to test fit it and just grabbed closest one.
    Haven't posed in a while still plugging along on the body work. Its almost all done now. My family car Taurus SHO blew a turbo so had to take some time off the Buick for a bit. I ordered all the weather striping , chanel runs , window seals every rubber part on the car that wasn't cheap. Was hoping to be painting by now but got pushed back a bit when falimly car died. Bit more sanding and shaping then I'll primer it again block sand final time then finally paint time !
  17. gatz
    gatz
    might have missed it....but, re: the front suspension. Were your stock components in good condition?
  18. patterg2003
    patterg2003
  19. Mack0331
    Mack0331
    from Auburn WA
    No. I replaced everything with the suspension. Really I'm replacing or rebuilding pretty much every part on the car.
  20. Mack0331
    Mack0331
    from Auburn WA
  21. gatz
    gatz
    sent PM
    Mack0331 likes this.
  22. Mack0331
    Mack0331
    from Auburn WA
    Anyone have any opinions / experience with speedway wiring harnesses ?
  23. coupe33
    coupe33
    Over the years I have installed two. They are fine but I have been told that the American harness is better. I just bought one for my Pontiac . As far as I an concerned I hate the wiring of a car too tedious.
  24. Mack0331
    Mack0331
    from Auburn WA
    Finished all the body work. Got it all apart and its paint time ! Here's a sneak peak 1st coat going on.
  25. Mack0331
    Mack0331
    from Auburn WA
  26. Fabber McGee
    Fabber McGee
    Looks good, did you apply the paint yourself? Your shop is losing the fresh and shiny new appearance and getting the "lived in" look. Congratulations.
  27. Mack0331
    Mack0331
    from Auburn WA
    I did some of the body and paint. I have a friend that's a paint and body guy that helping out. I've done body and paint some before but I don't think I have the skill and experience to do the kind of quality I want and I don't want to take any chances with $680 a gallon paint.
  28. Fabber McGee
    Fabber McGee
    I've done both too, actually had both as professions in my youth (not at the same time). Seems like a really good painter and a really good mechanic are usually not the same guy. Different sort of brain activity or something. Sort of like the difference between men and women, they just don't think and react the same, haha.
  29. Fabber McGee
    Fabber McGee
    Your wife must be starting to show some interest now that it's getting color. That usually completely changes their at***ude. ... or has she been on board the whole time?
  30. Mack0331
    Mack0331
    from Auburn WA
    My wife is fine with me doing it but she has no interest in cars herself. Since I am a mechanic working on cars for a living kinda takes all the fun out of it. I don't really enjoy it too much anymore. I told her at the start I'm only gonna do this once so I'm going to spend a lot to make sure its all right the first time cause I won't want to work on it for a while after I'm done ! So she really couldn't care less about what I'm doing out in the shop lol . Building this hasn't been too bad cause I work on brand new cars at work so at least this is something different but it is still a challenge sometimes to come home from working on cars all day and work on mine . It is awesome to see it with some color on it now though the body work has been a long road to get to this point.
