Technical 57 chev wagon coil cutting and let's start a lowered wagon thread
Discussion in 'The Hokey Ass Message Board' started by skidlid, Mar 12, 2015.
  1. skidlid
    skidlid
    from motor city
    Hi hambers I have a 57 chev wagon and have the front coil springs out, how much can I cut?? I was going to cut
    1-1/2 coils off is this acceptable to drop approx 3 inches
    Any thoughts??
    There must be lots of guys on here with experience with this!!!
    Thx for any help
    The hamb is where it's at!!!!
  2. HOTRODPRIMER
    HOTRODPRIMER
    From experience I would take it slow,it's amazing just how much difference a half a coil will make.
    Granted it takes more work but once you cut it you can't undo it.
    BTW,don't ever use a torch to cut coil springs. HRP
    lothiandon1940 likes this.
  3. Schwanke Engines
    Schwanke Engines
    I take half a coil at time, but have the luxury of 6 hoist 's
  4. slammed
    slammed
    Generally, one full wrap will net 2" of drop.
  5. skidlid
    skidlid
    from motor city
    Thx guys
    Always lots of help on here
  6. slammed
    slammed
    Not to make more work, but these '55-70 Chevy can have the lower A-arm stepped 2" and ride like stock. So-Low did my '61's.
  7. skidlid
    skidlid
    from motor city
    What do u mean by stepped?
    Thx r
  8. slammed
    slammed
    This is the idea. Moving the ball joint platform up 2". And if your ride has a lot of shims already, moving the joint inward a bit can eliminate that.
  9. Lone Star Mopar
    Lone Star Mopar
    Slammed, you able to get a bump stop on yours ?
  10. slammed
    slammed
    Yes. It has never hit it. Been driving these lowered chevys for nearly 30 years. Sense-a-trac Monroe's should be figured in minimum. Nice ride, $25-$30 ea. Some one should be able to help w/a cross reference # for you. If you take out 2" or more a 1-2" shorter shock is a good idea. The stepped A-arm deal is like a spindle drop, it does not shorten the coil, hence shock is stock (longer) length. I have KYB's and they are fine for cutting harder corners, but then give up some comfort in the ride.
  11. partsdawg
    partsdawg
    from Minnesota
    Station wagon springs have a different rating than regular p***enger cars.
    We used to put wagon springs in '57 hardtops and coupes to raise the front end up.
    A set of 6 cylinder springs would be the weakest.
    Sure there is info on that somewhere on the web or call a spring shop.
  12. slammed
    slammed
    Also someone may be upgrading to bags or MII, stub, ect and may have these parts for cheap.
  13. Bosco1956
    Bosco1956
    from Jokelahoma
    6 Cyl springs might be stronger than you think since a 235 is heaver that a sbc ??
  14. chevy57dude
    chevy57dude
    X2 that the stovebolt weighs more. Not by much so the springs may not be different.
    Skidlid - All the rebuilt , powdercoated stuff from my 57 is sitting in a box here. Including brand new PST springs. PM me if interested, it's never going back on my car.
    slammed likes this.
  15. Lone Star Mopar
    Lone Star Mopar
    @slammed thanks for the response. Our 57 is stepped as is my 52. I think shorter shocks may be in order, I used new Monroe' s but theyre stock length and new 1.5 "drop" springs. Doesn't sit as low as others I've seen but were happy with it for now.
  16. Lone Star Mopar
    Lone Star Mopar
    For reference this is where she sits now. Looking for some 14''s up front for more rake.
  17. belair
    belair
    Remember- if you cut the springs it makes the spring rate higher. They will be stiffer.
  18. lots of great research on this subject on ChevyTalk.com in the tri5 forum. When I lowered my 57 Townsman I elected to just use new replacement springs and drop spindles and disk brake conversion to get it all taken care of in one step, fresh, low, safe. Got my spindles from Heidts
  19. ....by the way, I did attempt the spring cutting first by taking out one full coil to see what I'd get out of it. It went down more than 2", but others results may vary due to age and amount of wear on your springs. Just my $0.02
  20. mr57
    mr57
    If I remember correctly, every 8" of outside cir***ference drops it 3/4"......
  21. Thus is common drop for most of what we play with. I never cut more then a coil and a half and on some cars a coil and a half will be between 3 and 4"
  22. BadgeZ28
    BadgeZ28
    from Oregon
    I did just over a coil off the fronts on my 1955 wagon. It dropped it just over 2 inches. Looked nice but I didn't like the rough ride, so I bought 2" drop designed new springs.
  23. skidlid
    skidlid
    from motor city
    Here's the result, chopped 1-1/2 coils off, could have done 2
    It dropped approx 3-1/4 inches, the rear leafs were pretty sagged
    so front end was in the air, it was driving me nuts!!?,
    Now the car sits nice, pretty easy job just time consuming!
    Thx for all the help, first time for everything... Now I can add it to the list
    slammed likes this.
  24. skidlid
    skidlid
    from motor city
    Nice wagon, sits low
  25. Lone Star Mopar
    Lone Star Mopar
    Thanks, yours looks great. !
  26. bchra guy
    bchra guy
    my 65 Impala wagon has stock coils cut 1 1/2 each......good quality shocks as well......rides OK for this lowering method......best bet will be spending the $$$$ to acquire special progressive rate coils, which will provide same drop but with improved ride quality...... IMG_1187.JPG IMG_1190.JPG
    papajohn and lothiandon1940 like this.
  27. manyolcars
    manyolcars
    I am using 550x15 tires on the front of the 57 wagon that I have had for 25 years. No way I would lower ANY. The front crossmember already hits the pavement during aggressive driving
  28. The HellyDid
    The HellyDid
    from Florida
    Mines a '57 but not a wagon.....This is what was done on mine when I got it (torched), I replaced with 2" lowered springs, now good ride and height.
  29. SmokinBill
    SmokinBill
    1" coils and 2" dropped spindles. rides like a dream and has the look.
    chevy57dude and Paul B like this.
  30. skidlid
    skidlid
    from motor city
    ******Hi guys I Got another question, I believe my p***enger side is 1/2inch to 5/8 higher, I left car overnight
    So may cut the other 1/2 of coil off on p***enger side
    Any thoughts I looked at all other possible issues and points to the spring....
    Thx and keep the cool lowered wagons a postin
    These were the original mini vans back in the day
    I grew up with a few different wagon, everybody young or old loves em, I think they bring back memories for a lot of people and the younger generation thinks they are cool, so we must be on to something here!!!!!
