Trying to find the part numbers for the roller bearing upgrade. I know CPP sells the kit for $95. I am trying to piece this together at a local bearing house for less. Rock Auto lists the Timken B45 front outer, and the B46 for the front inner. Is this what I am looking for? If anyone is doing the upgrade now I would greatly appreciate the PN's directly off of the bearings. PS. I also know the original roller PN's are 909052R inner bearing 909001R outer bearing 6064 seal inner <TABLE style="BORDER-BOTTOM: 2px groove; BORDER-LEFT: 2px groove; BACKGROUND-COLOR: white; BORDER-COLLAPSE: collapse; BORDER-TOP: 2px groove; BORDER-RIGHT: 2px groove" class=main><TBODY><TR id=table394part0 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>NATIONAL Part # B01 Ball Bearing; Bore=0.7498", Outer Diameter=2.0805", Width=0.713" Front Wheel; Outer; Base Model</TD></TR></TBODY></TABLE></TD><TD class=right></TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node394part0price class="center leftrightborder boldfont priceonly alternate0">$31.79</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node394part0altfiller class="center boldfont leftrightborder pricebreakdown alternate0"></TD><TR id=table394add0 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate0 center">Add Part </TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate0 center"><INPUT id=node394part0alternate type=checkbox name=alternate></TD></TR><TR id=table394part1 class=part1><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>NATIONAL Part # B40 Ball Bearing; Bore=1.2504", Outer Diameter=2.564", Width=0.759" Front Wheel; Inner; Base Model</TD></TR></TBODY></TABLE></TD><TD class=right></TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node394part1price class="center leftrightborder boldfont priceonly alternate1">$51.79</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node394part1altfiller class="center boldfont leftrightborder pricebreakdown alternate1"></TD><TR id=table394add1 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate1 center">Add Part </TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate1 center"><INPUT id=node394part1alternate type=checkbox name=alternate></TD></TR><TR id=table394part2 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>TIMKEN Part # B45 Wheel Race; 0.8 in. Width RWD; FRONT OUTER</TD></TR></TBODY></TABLE></TD><TD class=right></TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node394part2price class="center leftrightborder boldfont priceonly alternate0">$55.99</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node394part2altfiller class="center boldfont leftrightborder pricebreakdown alternate0"></TD><TR id=table394add2 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate0 center">Add Part </TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate0 center"><INPUT id=node394part2alternate type=checkbox name=alternate></TD></TR><TR id=table394part3 class=part1><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>NATIONAL Part # RW307R Ball Bearing; Bore=1.378", Outer Diameter=3", Width=1.298" Rear Wheel; Base Model (Only 4 Remaining)</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right> </TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node394part3price class="center leftrightborder boldfont priceonly alternate1">$62.89</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node394part3altfiller class="center boldfont leftrightborder pricebreakdown alternate1"></TD><TR id=table394add3 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate1 center">Add Part </TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate1 center"><INPUT id=node394part3alternate type=checkbox name=alternate></TD></TR><TR id=table394part4 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>TIMKEN Part # B46 Wheel Race; 1.236 in. Width RWD; FRONT INNER</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
if i didnt already have mine together i would get the part numbers for you. if it comes down to it ill pull one side down and get the part numbers for you this weekend, because i have another 58 to upgrade as well
