I am trying to get the factory switch to work but am banging my head on the wall. Anybody got a simple diagram showing what goes where? My cheapie ezwire booklet doesn't quite show me anything.
If I remember on my car correctly the switch wiring is almost identical as a 79-87 C-K1500, except the front parking lights drop out when the lights come on with the 57.
I found this diagram, hope it helps. http://www.tocmp.com/tOCMP/wiring/5765wiring diagrams/Chevrolet/MWireChev57_3WD-056.jpg
http://www.tocmp.com/tOCMP/wiring/5765wiring%20diagrams/Chevrolet/MWireChev57_3WD-057.jpg hope this helps
Thanks..I have something similar but like I said...its causing bruises on my brain..guess I just need to blow it up bigger so my old eyes can trace the lines better. Thank you guys.
Red is your main power, Yellow goes to the high beam selector, Purple is front parking lights, Black is rear parking lights, White is dome lights, Orange is something for the brake lights also I believe, Dark Green is dash lights.
That would probably solve it...I had an extra hot on the green(I think) and my taillights stayed on. I'll try the orange.
Well, did it work? If not PM me and when I get home I will look through my pile of paperwork, and old switches, harness .....
Maybe this will give a little more info: 1>Red is Battery and hot all the time. It is unfused going to the headlight switch but the switch has a fuse in it for the headlights. 2>Orange is fused 12 volts hot all the time. It is connected to several circuits, including supplying power to the brake light switch, but on the headlight switch it doesn't do anything for the brakes. It supplies power to the rear running lights and dash lights so that when its fuse blows you will notice that the dash and running lights are out without having to look at the back of the car. 3>White is grounded by the switch to turn on the dome light. 4>Violet (purple) is the front parking lights. It goes on in the parking light position and is off in the headlight position. 5>Yellow is "headlights on" power to the dimmer switch. 6>Dark green feeds the fuse for the gray wire for the dash lights. 7>Black is rear running lights.
OK thats it. Thank you all...I had the orange wire hooked up wrong!! On to the next challenge....I may get this damn thing back on the road this year yet!!!
