Technical 57 Chevy Inner Quarter Replacement
Discussion in 'Traditional Customs' started by RodBender57, Sep 4, 2016.
  1. RodBender57
    RodBender57
    from JawJah
    I'm about to replace the entire inner quarter panel ***embly on my '57 Chevy, 2 door hardtop. The unit I have purchased is the mini tubbed version from Real Deal Steel.
    All the info I have found on this repair suggests that the outer quarter panel must be removed first.
    Has anyone replaced one of these without removing the outer quarter panel? Please note that the entire floor/trunk panels are removed from the body, which should be a big help, and the body is off the frame.
    Thanks
  2. Willy_P
    Willy_P
    rodbender57
    Based on the available information (or lack thereof) The trifive rear wheel housing/rear quarter/inner quarter area seems to be a mystery on how to dis***emble/patch/re***emble especially if you have never seen the inside before.
    I would suspect at a minimum there would be spotwelds where the inner and outer quarter pieces touch that would need to be separated.
    It would be worth a call to inquire how to install these pieces based on how much you have dis***embled.
    Real Deal Steel Contact
    Tel: 407-585-1957
    1220 East 30th Street
    Sanford, FL 32773
    Email: info@realdealsteel.com
    Store Hours: 8:00am - 5:00pm EDT
    The following sounds like a lot of work to avoid removing the outer quarter.
    But if the top of the existing inner quarter is in good shape, you may consider using a cutwheel to carefully cut the existing inner quarter close to where the two inner and outer pieces join.
    Then set the new piece in place and scribe where your previous cut matches on the new piece.
    fit/trim into place and spot weld.
    My 57 was blown apart and all the parts were stacked in the car when I bought it.
    Both of the outer quarters had been repaired using 3 or 4 pieces cobbled together on each side and bondoed/primered.
    It actually looked decent.
    However when I had the car ***essed for painting, they could see in the wheelhousing because the wheelwell extension was not installed yet.
    They pointed out that the car appeared to have been left outside in the weather, and the inner welding was rusted. They would not guarantee the paint unless they replaced the quarters, so that is what I had them do.
    I attached some photos of what the car looked like with the quarter removed, so perhaps that will help you visualize your task.
    The links below are not exactly what you need do do, however, they will give you some views into the area you will need to work in.
    Trifives are mostly the same ***embly in the rear wheel housing and inner trunk.
    websearch
    how to replace a inner quarter panel on a 57 chevy
    How to Replace a Quarter Panel on a 1955 Chevrolet Bel Air - The Full Quarter
    Solving the Tri-Five quarter-panel blues, thanks to Real Deal Steel.
    http://www.superchevy.com/how-to/pa...place-a-quarter-panel-1955-chevrolet-bel-air/
    Building a 56 in the backyard.
    http://www.trifive.com/forums/showthread.php?t=128960
    How hard is it to replace this inner quarter?
    http://www.trifive.com/forums/showthread.php?t=91810
    1957 chevy belair full quarter panel replacement
    1957 Chevy Bel air frame off restoration (Danny)
    RodBender57 likes this.
  3. squirrel
    Do you need to replace all that metal? or do you want to replace it?
    My philosophy is to replace as little metal as is necessary, and leave as much original metal as possible.
    If you only need to replace the wheel tub, then only replace the wheel tub. If there is rust in the upper parts of the inner fender, then you probably ought to remove the outer quarter panel, too. You will probably want to replace the outer, as well, right? It's only money.
    Ribbedroof, Kan Kustom, Baumi and 2 others like this.
  4. RodBender57
    RodBender57
    from JawJah
    Willy_P,
    Thanks for all the great info and pics. Your car looks great. I really like the colors.
    I have already emailed Joe at Real Deal Steel. His knowledge is basically limited their build process for a complete body. The first sub***emblies they set in their jig are the floor/trunk panels and the inner quarter panel ***emblies. He didn't think I could install an inner quarter without removing the outer, but I don't have the floor/trunk pans in my way.
    The inner quarter only contacts the outer at the lip around the trunk opening. The wheelhouse lower flap is spot welded to the outer quarter in one spot. The inner is also attached at the B pillar. The rest is attached at the C pillar and under the package tray.
    So much of mine is rusted away around the wheelhouse that it would cost nearly as much to buy the front patch, wheelhouse, minitub, rear patch & rear corner patch as it would cost to buy the complete ***embly. Also, I don't want a Frankenstein of a pieced together repair, even if it's almost all hidden.
    I have looked at it long and hard, and I'm pretty sure I can do it without cutting into the outer quarter panel.
    I will add some pics over the next couple of days.
    Thanks again!
  5. RodBender57
    RodBender57
    from JawJah
  6. aaggie
    aaggie
    You should consider some serious cross braceing from every possible angle before cutting out that much structure. The body will twist and it will be difficult to get it all back in alignment. Lots of tack welds and measureing before making it solid.
  7. Willy_P
    Willy_P
  8. RodBender57
    RodBender57
    from JawJah
    20160816_234926.jpg aaggie, this was my brother's car in the 80's. Against our Father's advice, he took the body off the frame without installing ANY bracing in the late 80s. He lost interest in it and the car and frame sat on the ground in our parents back yard until my father built a garage in the mid 90s.
    At that time, he had the garage builder to scoop the body up with a skidsteer loader and deposit it on the new foundation of the garage. The body is surely completely distorted. At this point I'm holding everything together with sheetmetal screws until I have the inner quarter, floor/trunk, tail pan, doors and deck lid back on and everything bolted to the frame. I know it's going to be a struggle to get everything realigned, but that's where I am.
    Thanks
  9. Kan Kustom
    Kan Kustom
    Watching.
  10. RodBender57
    RodBender57
    from JawJah
    Willy_P, I had the ch***is together before I ever got the body started. Had a 9" narrowed. Ladder links w/coilovers. Stock front suspension with dropped spindles and lowering springs and disk brake conversion.
    This is a picture with the mock up 427 tall deck in it.
    Kan Kustom likes this.
  11. squirrel
    you just need one of these jigs.....
    Fedman and RodBender57 like this.
  12. RodBender57
    RodBender57
    from JawJah
    I wish. :) I have wondered if there is anybody who could take my body, put it in one of these and weld it together. It sure would simplify things.
  13. Fedman
    Fedman
    That Body Jig is a really nice Piece!
    I would be afraid to ask the Cost of it though..............
  14. RodBender57
    RodBender57
    from JawJah
    Yep, and having everything clamped and located on the interior like that wouldn't guarantee that the exterior panels would align, but it would be a good starting point.
  15. Willy_P
    Willy_P
    If you watch the YouTube video I posted, that is about as scary as it gets, but Danny and his buddies took it slow, and it came out fine
    ...a roof and a ***le for $500...LOL
    MyCrustyVW and RodBender57 like this.
  16. squirrel
    Having a good body to measure, would be a big help, eh?
  17. RodBender57
    RodBender57
    from JawJah
    I came across that video a couple of weeks ago and it is one of the reasons I wondered if I had to cut the outer quarter panel off to replace the inner quarter panel, as Danny says they did.
    I was going to send Danny an email, but I noticed that his grandkid posted that Danny had since p***ed. Very sad.
  18. RodBender57
    RodBender57
    from JawJah
    Joe at Real Deal Steel has been very helpful about providing me with some measurements.
  19. RodBender57
    RodBender57
    from JawJah
    Just a quick update. I spent the morning finding and drilling out spot welds. I am definitely going to be able to remove and install the inner quarter without removing the outer quarter.
    I'll post some pics soon. I have it about 1/2 way removed now. 20160910_100437.jpg
    Willy_P and biscaynes like this.
  20. wheeldog57
    wheeldog57
    Rodbender, that is a ton of work. When I was restoring mine, the wheelhouses fell out. In the early 90s, the inner panel wasn't readily available so I made my own pieces to hold the wheelwells. Yes, lots of work but WAY LESS than what you are doing. I moved the wells in so they are up against the frame and added a strip in the middle to make up the difference. My own mini tubs. That was my first fabrication on an old car. Still holding up and looking ok after 8 years of driving. 1473636852529.jpg
    Sent from my SM-G900V using The H.A.M.B. mobile app
    chevy57dude, RodBender57 and pat59 like this.
  21. RodBender57
    RodBender57
    from JawJah
    That's sweet. The hard part, I'm afraid, will be getting everything aligned again. I would rather plug weld 100 holes than make 10' of bead welds that have to be ground, filled and smoothed. Those mini tub mods are A LOT of work too, and I don't have the floor /trunk pans in my way.
  22. RodBender57
    RodBender57
    from JawJah
    To all those guys that told me it couldn't be taken out without removing the outer quarter panel, 20160912_101736.jpg ... PFFFTT! ☺
    Torkwrench and MyCrustyVW like this.
  23. RodBender57
    RodBender57
    from JawJah
    I'll take a few more pics and post a step by step explanation as to what to expect, in case anyone else is facing this task.
  24. Sure, you didn't have to remove the quarter, you took everything from the other side of the wheelhouse away.:)
    Willy_P likes this.
  25. RodBender57
    RodBender57
    from JawJah
    As I stated earlier, I had been told by several experienced sources that I would have to remove the outer quarter panel anyway, including Real Deal Steel.
  26. Yes. What's that saying?
    "There's more than one way to skin a cat." Outside/in. or Inside/out. You're doing a great job.
  27. RodBender57
    RodBender57
    from JawJah
    Well, there she is. Only took a couple of hours of bending, jacking, pushing, pulling, beating and squeezing to fit it in place. All in all, I'm pretty happy with the fit.
    Floorpan is coming next.
  28. Teamchevy
    Teamchevy
    How's your progress been since last fall?
    Dave
    Kan Kustom and RodBender57 like this.
  29. RodBender57
    RodBender57
    from JawJah
    20170405_030254-1.jpg 20170327_000828.jpg 20170327_000745.jpg Very slow. I have the floor in and everything is held together with sheetmetal screws. Been working on the trunk area and getting the door gaps adjusted.
    Kan Kustom and Johnboy34 like this.
  30. Wow! There wasn't a lot of '57 Chevy left in a couple of those last pictures you posted!!! I love these kind of reads - excellent work!
