Hot Rods 57 Chevy rear view mirror keeps falling
Discussion in 'The Hokey Ass Message Board' started by Bigstar, Jul 1, 2016.
  1. Bigstar
    Bigstar
    from Austin
    So I have this little issue that is driving me nuts. The rear view mirror on my 57 has gotten really loose. Driving down the road it keeps falling so that it's facing the floor. I adjust it and 10 minutes later it's facing the floor again. I would rather fix it than replace. Any thoughts??
  2. squirrel
    loc***e? But first look at it and see what's wrong, are the threads in the screw hole stripped?
  3. Gman0046
    Gman0046
    Aside from Chevy mirrors not staying in place sunvisors do the same annoying droop. Anyone have a solution other then loc***e? I've read several threads stating the kits to repair the sunvisors are worthless.
    Gary
  4. 270ci
    270ci
    A big wad of well chewed bubble gum is a traditional fix....and Bazooka brand is the best. :rolleyes:
    bobss396 likes this.
  5. low budget
    low budget
    from Central Ky
    I think he is saying the mirror housing part is loose on the pivot ball part, Ive seen em get loose in diffrent cars and trucks but dont know that Ive ever fixed one. I wander if you could take it off and cautiously go around the edge of the ball housing with a hammer and chisel (screw driver) and knock/press the edge of the housing in enough to tighten it.
    ....or maybe you could mar the ball with a center punch or sharp chisel while having the mirror turned away from the area of the ball you are working on then turn and do another area of the ball???
    I think squirrel maybe thought you were talking about the threads and maybe you were but the loc***e might work on the ball as well??? or some JB weld would hold it in place but if you didnt want it locked in place you might also try a thin coat on the ball in a area while the mirror is turned as far away from it as possible then after it dries turn it back over the area to create a shim...???
  6. 325w
    325w
    Find a used one that's not limp
  7. 302GMC
    302GMC
    from Idaho
    Tiny br*** shim washer in the wedge works.
  8. I agree with Squirrel. I had the same problem with my outside mirror on my Oldsmobile station wagon . I backed the screws out and put some Loc***e on the threads and re tighten them .Havent had a problem since then and I always have problems. lol. and good luck. Bruce.
