Hot Rods 57 Chevy Truck Help
Discussion in 'The Hokey Ass Message Board' started by Tin Indian, Sep 17, 2019.
  1. Tin Indian
    Tin Indian
    So, I want to put a set of swinging pedals in my 57 chevy 3100 truck, and move the master to the firewall. Im running a t-5 trans in it and I need a pedal set up that has both clutch and brake pedals. I found just a brake pedal with the dash support in it, and that;s what I want, but I need that clutch pedal. Does anyone know of anyone making a brake and clutch pedal set for this truck? I thought it be an easy find, but I was wrong. Im sure Im not the first person to try this. I figure someone makes a bolt in pedal set and dash support unit. Any help would be appreciated.
  2. They are all over ebay- use 1959 or 55-59 in your search
  3. Moon50F3
    Moon50F3
    I used the setup from Kugel Komponents. Built a brace to the dash and also for the firewall to spread the load a bit. I only got the brake, but I know they make a 2 pedal version. I thought it was a pretty nice unit.
  4. Tin Indian
    Tin Indian
    I see a lot of brake pedal brackets, but no dual pedal set ups on ebay. Ill check out Kugel.
  5. wheeltramp brian
    wheeltramp brian
    Kugel has a nice one.it worked perfectly in a 59 I worked on
  6. swade41
    swade41
    from Buffalo,NY
    CPP offers one for a 60-66, make your own brace to dash
    #_MT6062BB2
