Technical '57 Corvette horns
Discussion in 'The Hokey Ass Message Board' started by 1971BB427, Nov 7, 2024.
  1. 1971BB427
    1971BB427
    from Oregon
    Hoping for some input on how they were wired, or how they get the signal to honk?
    I'm helping a friend who bought a '57 Corvette earlier this year, and there were no horns. He got a pair of new replacement horns and before installing them I looked behind the grille and located what is likely the feed wires, one at each side of the grille. But I put a test light on them and as soon as I connected the test light to the wire it lit up, and I hear the horn relay pull in.
    I ***umed the wiring to the horns wouldn't have power constantly, but this does. Seems maybe either I'm wrong about how it's wired, or maybe there's an issue in the horn ****on that's keeping power to the horn constantly?
    Anyone who can maybe give some guidance as to how the system works, or whether it's constant hot, or ???
  2. squirrel
    Look for the wire from the steering column that connects the horn relay contact, in the upper bearing, to the horn relay.
    The wiring is pretty simple, the horn relay gets power all the time, and it gets ground when you push the horn ****on. When that happens, it sends that power up to the horns. On a corvette, make sure the horn ground wires are in place...look at the ***embly manual for all the details. If he doesn't have the ***embly manual, he needs one. Really.
    The relay could be wired wrong.
  3. squirrel
    oh...there is a pdf of the 57 AIM on the internet, search for
    1957AIMwebOCR.pdf
    but it might be hiding well.
    1971BB427 likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Relay maybe wired incorrectly or stuck closed
  5. 1971BB427
    1971BB427
    from Oregon
    Thanks!!
    The relay appears to have unmolested wiring that's original, so maybe the horn ****on is somehow making all the time. When I used my test light on it I found the left and center terminals both were hot, and nothing on the right terminal. I expected to only see power on the one terminal, so guessing maybe the horn ****on, or column wiring is shorted?
    When I put my test light on the two wires out at the horns I hear the relay making noise with the test light load on it. Going to look into the steering wheel and see if I can find a reason the horn wires are constantly hot.
    Any idea if the horn ****on just pries off the wheel, or how it's attached?
  6. nosnhojguy
    nosnhojguy
    pushes in and turn if I remember right.
  7. squirrel
    pulls straight out. Other brands of cars have to twist first, but not Chevys.
  8. 1971BB427
    1971BB427
    from Oregon
    Thanks. I'll disconnect the battery and try removing the cap.
