57 fuely dist
Discussion in 'The Hokey Ass Message Board' started by olscrounger, Mar 1, 2010.
  1. olscrounger
    olscrounger
    Chevy gurus--need a little insight-
    fired the car a few days ago--runs fairly well but having issues with the dist--it's an FI dist with the pump drive, etc and had dual pts--it is really hidden behind the unit and I can't see as well as I did 30 yrs ago--anyway can't get the dwell to where it needs to be--supposed to be 34 degrees with dual pts--got it to 30 but that's the best I can do-( I set it up out of the car with the pts at .016 prior to install-dwell was at 12 degrees!)-also won't run right with timing below 12 degrees advance--book says 4-8
    any help/advice appreciated--one old timer told me to disable the leading set of pts and it will run much better
    I guess the next chore is to remove dist and put it on a Sun machine
    THX in advance for any help
  2. flt-blk
    flt-blk
    from IL
    Get it on the Sun machine is probably your best bet, they can also check you condensers and coil.
  3. Deuces
    Deuces
    I believe the dwell is suppose to be 32 degrees.. Any chance you can set the gaps at .019" on the points??? I could be wrong, but I hope not!
  4. olscrounger
    olscrounger
    Fuel injection manual says 34 degrees for this dist in the 283 HP mtr--I can try 19 and see--manual says 4-8 dgrees advance but it won't run there very well--at 14 degrees it runs pretty good and has 15.5 inches of vacuum and steady--idle is at 850 but thats about where an 097 cam wants to idle from past experience--had a 62 340HP 327 with this cam and a wcfb and it didn't like to idle below 800 and it's a little larger CI so the cam is less lumpy than in a 283. I knew this thing was going to test my dedication--it drove me crazy 30 yrs ago til I got it dialed in--back then I just set the advance with a vacuum gauge then drove it and advanced til there was a slight ping then backed it off and never fooled with it much after that other than set valves, etc.
  5. 61bone
    61bone
    Put a piece of cardboard in one set of points and set the dwell. Now put the cardboard in the other set and set the dwell on the first set.
  6. aaggie
    aaggie
    I agree with last entry. I had a real fuelie '57 way back when and you have to set the dwell on each set of points. I remember working on the car and the wife called me in for Supper just after setting the first set. When I resumed after several adult beverages I blocked the second set and it took awhile to figure out where the fire went.
  7. olscrounger
    olscrounger
    did the paper in each pt trick already--just did again and it's now at 34 degrees--runs good but likes about 14 degrees of timing-book says 4-8-has 16 1/2 inches of vacuum and steady --idles at about 850--haven't really leaned on it yet -just driven around neighborhood-so far so good I guess
  8. Royalshifter
    Royalshifter
    Moderator
    Tim........I figured your wife would have black lined the street by now!!!!
