57 GMC Foreverbed Project
Discussion in 'Off Topic Hot Rods & Customs' started by EnragedHawk, Aug 14, 2024.
  1. EnragedHawk
    EnragedHawk
    from Waco, TX
    Back with another project. I just picked up this 1957 GMC, looooong bed stepside. Believe it or not, this body is actually way worse than it initially looks. My guess is that someone watched too many master fabricator shows in the 90’s and figured they could do it too (I may be guilty of this too).
    The body filler has been caked on and sprayed over. It looks great from 20 feet and decent in pictures. There’s some questionable frame work done that also has body filler for some, likely insidious, reason. I was told the frame is from 19 It has a 350 and a manual 3 speed. It’s smoking pretty bad, but actually runs decent. I way waaaay waaaaaaay underpaid for. Despite its condition, it was a steal at $500. I would love to make some kind of traditional styled hauler out of this one tow my 53 Olds behind.
    IMG_8123.jpeg IMG_8125.jpeg IMG_8124.jpeg IMG_8127.jpeg IMG_8128.jpeg IMG_8129.jpeg IMG_8130.jpeg IMG_8131.jpeg IMG_8136.jpeg IMG_8135.jpeg IMG_8134.jpeg IMG_8133.jpeg IMG_8132.jpeg IMG_8110.jpeg
    Current plan is to rip the front end apart and see what has been cobbled together on it. I need this thing safe. I’m supposed to be building it for my wife. Most pressing issue is the tires. They look good, but super old. The current wheels have grown on me, but I know they’re not traditional, so I picked up a set of steel wheels. My wife wants to do the truck in black and teal, so may go with teal wheels and chrome center caps. Here I am wide open to ideas. As a hauler, I think some beefier tread would look cool, but didn’t know if that would follow traditional guidelines. I love me some white walls, so I’m not object to the painted steelies, chrome caps, and white walls. Again, open to ideas.
    Considering either of these:
    If I go with whitewalls, the truck has to come down. A lot. Like, maybe an inch… off the ground. Did you guys know Rustoleum makes white walls?
    Anyway, please provide any and all input. I know it’s a long bed. It’s growing on me, but I’ve considered shortening it. Right now, what I want is a good and functional truck, so the bed despite its overcompensating, is super useful.
    Pushed my luck a little far over the last couple weeks driving the truck pretty regularly. I haven’t done any maintenance or repairs besides replacing the fuel pump. So, I really lucked out a couple days ago. Drove the truck to work with no issues, but ran out of gas on the way home. Easy enough. But it pulled dirt from the bottom of the tank and clogged the fuel filter. Swapped the filter and likely clogged a jet. Truck runs like **** now.
    Hopefully I have time to work on it this weekend. I need to do a lot of basic maintenance anyway. Oil/filter change, plugs, wires, valve cover and exhaust gaskets, clean the carb, and clean the engine. As soon as I settle on tires, I’m getting those done too.
    Okie Pete, 29A-V8 and swade41 like this.
  2. leon bee
    leon bee
    Just one dummy's opinion, but wide whites be totally wrong.
    29A-V8, 67drake, Dick Stevens and 3 others like this.
  3. finn
    finn
    If you’re planning on towing with it, keep the long wheelbase. Much better stability, plus, lab fifties trucks are cool.
    Say no to wide whites. They’re overdone.
    29A-V8 and EnragedHawk like this.
  4. 57 Fargo
    57 Fargo
    Nothing wrong with a long box. Cool truck.
  5. EnragedHawk
    EnragedHawk
    from Waco, TX
    Ok, super cool to hear not everyone loves white walls. I already have them on my 53, and they're cool, but I'm not really wanting to go all lowrider this time. Can I get away with the BFG AT's on a traditional truck? How about the current wheels? They look too 90's to me. I wouldn't mind the AT's on the steel wheels.
  6. Budget36
    Budget36
    There’s more there than you can buy separately for 500? I think you got a deal.
    Look at the front wheels/tires, where the ride height is at now, they look too far forward, lowering it will add to that.
    I’d expect major surgery to correct the front end.
    Maybe look for a ‘55-9 LWB frame?
    Can be lowered, made to ride nice, and much easier to put the front axle where you want it.
    Hey, you did ask for opinions;)
    Edit: I know 58/59 PUs the front frame rails were an 1
    Inch or two longer on Chevies. But no clue(easily correctable) about the GMCs.
    EnragedHawk likes this.
  7. lumpy 63
    lumpy 63
    Screenshot_20240814_131608_Chrome.jpg Looks like the original frame that someone did a front clip on. Check it carefully
  8. guthriesmith
    guthriesmith
    Pretty sure you stole it for $500. And, I had a 58 Chevy long bed that kind of grew on me especially after I lowered it. Should make a cool hauler. Congrats!
    Oh, and I wouldn’t put the 4x4 tires on or keep the wheels if you are looking for it to be sort of traditional. I would just put some regular black walls on some steel wheels with dog dish hubcaps if it were me.
    EnragedHawk, Budget36 and lumpy 63 like this.
  9. 57 Fargo
    57 Fargo
    As you may see I have no problem with white letters on cool trucks. I would skip the wide whites though. I’m going to put together a set of steel wheels for mine one day, just to mix it up a little
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Congrats on the truck, I am moving this to the off topic forum because of the wheels and the frame swap
  11. jfreakofkorn
    jfreakofkorn
    nice looking rig esp w it being a long wheel base
    nice price also w something running for 500,- nowadays , imo
  12. guthriesmith
    guthriesmith
    Here is the look I ended up with on my Chevy long bed.
  13. swade41
    swade41
    from Buffalo,NY
    My first of many 55-59's was a 57 GMC and was actually looking for another before buying my current 57 chevy.
    Those white walls were pretty hideous the way the whole side was white, so definitely don't use those.
    I was trying to buy this 55 that had a 9 foot dump bed, like you I'm looking to have a useful shop truck that can haul an open trailer. This one I envisioned low in front with a serious rake, tires sticking out the rear fenders, visor over the windshield and a pair of stacks behind the cab through the steps.
    Screenshot_20240817_010911_Gallery.jpg Screenshot_20240817_010954_Gallery.jpg
  14. AmishMike
    AmishMike
    Nice truck good buy. For safety sake, move the gas tank under the bed.
  15. EnragedHawk
    EnragedHawk
    from Waco, TX
    Thanks for all the replies! I still don’t know what I want to do with the wheels and tires. I need to get that figured out asap.
    I spent some time on the engine Saturday. Amazing the thing even ran before.
    IMG_8869.jpeg IMG_8870.jpeg IMG_8856.jpeg IMG_8868.jpeg IMG_8853.jpeg IMG_8867.jpeg
    Did valve cover gaskets, new distributor cap and rotor, new plugs, new wires, and cleaned up the rusty chrome as much as I could. Personally, I hate chrome under the hood. This will just have to do for now.
    After the tune up, the truck has way more power than I expected. Decent little 350. However, I am still suddenly losing power after driving for a few miles.
    Current guesses are either a clogged jet from when I ran the tank dry or vapor lock. Going to get a fuel pressure gauge on it and probably go ahead with an electric fuel pump. It’s a junk Edelbrock carb, but if I can keep it going for now, that’s what I’d prefer.
    After my first test drive, everything went great. But I came back out to the truck and fuel was pouring out of the gas cap. Obviously the tank is building some pressure somehow. Can I just replace the cap for a vented gas cap?
    anthony myrick likes this.
  16. swade41
    swade41
    from Buffalo,NY
    Yes and that may be your issue with it losing power.
    RodStRace, EnragedHawk, SS327 and 2 others like this.
  17. Looks like the front frame horns grafted from the original frame.
  18. squirrel
    When you get around to the front suspension, you first need to figure out what it is. Judging from the looks and how wide it is, my guess is 73-87 chevy pickup, with part of the frame grafted in. These later trucks had the same 34" frame width under most of the truck as the 55-59s, but the front end of the frame pinched in to about 28" where the crossmember is.
    If it has 5 on 5" bolt circle, that's likely what it is. also the rear end would be from the same later truck as the front suspension, most likely, and it would be a truck 12 bolt, with the same 5 on 5" bolt pattern.
    good deal, but it'll be difficult to lower it without redoing the frame, since the track width is more than you want in these old trucks....so if you're wife is OK with how it sits, you could just leave it "high" and not worry about that.
    EnragedHawk and guthriesmith like this.
  19. EnragedHawk
    EnragedHawk
    from Waco, TX
    Looks like most of the loss of power was due to a dirty carb. Pulled it off and cleaned it up, running great now! Added a fuel pressure gauge to keep an eye on things while I’m still getting to know the truck.
    I’ve been working on my needs vs wants list;
    Needs:
    Wiring
    Fuel pump
    Fuel pressure regulator
    Fuel sender
    Front end alignment
    Bed shims
    U joints
    Wheel bearings
    Diff & trans fluid change
    Bushings
    Wants:
    Rear bumper & brackets
    Trailer hitch
    Louvers
    Bed wood
    Painted mustache
    Carpet
    Sound deadening
    Exhaust cutouts
    Steering wheel
    Gauges
    Hardly a comprehensive list, but just what I’ve got going through my head right now. I did pick up a GMC mustache for the front. I tried some rattle can on it, but may still take it for paint. I found the parking lights in a box too, so won’t even have to go looking for them.
    I teach a super basic auto cl*** at a local middle school and also have an after school car club. I had the club learn how to change the oil using the truck.
    Sooooo…. I ended up keeping the wheels that came on it. I know they’re not traditional at all, but since I’m already in the OT section, I may as well share here. Not sure they’ll forever, but I like the look for now. Had them powder coated while I was getting new tires for them.
    Been driving the truck more and more. I still haven’t torn completely into the frame. It looks like the front clip is just grafted in. It’s a 73 clip for sure. The work isn’t as bad as I initially thought, but I need to rip it apart to be sure.
    I’ll be back when I know more.
    Okie Pete, 29A-V8, 67drake and 6 others like this.
  20. Stooge
    Stooge
    Digging it with the black wheels and new tires, and REALLY digging the Oldsmobile!
    Good on you for taking the time and showing the kids, im sure they're having a blast!
    AmishMike and EnragedHawk like this.
  21. e1956v
    e1956v
    Alliance Vendor
    I think the wheels and tires match the overall look of the truck and look fine.
    67drake and EnragedHawk like this.
  22. EnragedHawk
    EnragedHawk
    from Waco, TX
    Nothing new, but had to share. I gotta quit pushing my luck.
    Yesterday while I was at work, my wife asked if we could use the truck to go pick up a desk she wanted. I said sure, but warned her it has already left me stranded twice.
    Then she told me how far away it was.
    Anyhoo. I had AAA on speed dial, but managed to put 150 miles on the truck last night with very few issues. Have a bad vibration that kicks in at 60/65. Probably bushings. Kept it at 55 the rest of the time and ran great! Couldn’t believe it.
  23. deathrowdave
    deathrowdave
    from NKy
    You guys and western tin , are killing me ! All I get is 90% returned to where it started “ rust dust “! Great lookin truck my Buddy has a 55 Got A Mechanic a Comin with the big rear window . It’s kinda like ridin in a green house
  24. EnragedHawk
    EnragedHawk
    from Waco, TX
    swade41 and Okie Pete like this.
  25. shadams
    shadams
    Killer truck man, i know the feeling of wanting everything just right but sometimes you gotta just drive it and have fun, besides, for 500 that is a steal and you have the car too. Awesome find....
