'57 Hardtop Survivor Build Thread
Discussion in 'Off Topic Hot Rods & Customs' started by CTaulbert, Jun 17, 2024.
  1. rod1
    rod1
    How did I miss this? Too Cool.
    CTaulbert likes this.
  2. Ken Smith
    Ken Smith
    Alliance Vendor
    Looks great!
    Where did you connect the PCV hose on the WCFB carburetor? To the port in the rear?
    Where did you connect your power brake vacuum hose?
    Thanks.
  3. CTaulbert
    CTaulbert
    from Detroit
    I drilled the manifold behind the carb for a dedicated port to feed the PCV, booster, and wipers. I repurposed the carb base plate port for the vacuum advance.
    Tim and Ken Smith like this.
  4. Ken Smith
    Ken Smith
    Alliance Vendor
    Good idea.
    Thanks.
  5. CTaulbert
    CTaulbert
    from Detroit
    I've added about another 650 miles to the car, and it continues to impress. The stock 283 moves it right along.
    I've been thinking about adding air to the car this winter, and have been looking at the Vintage Air SureFit kits for it. I think I'll find some factory a/c dash vents for a more stock appearance? Alan Grove has a compressor bracket that uses the water pump and right exhaust manifold bolts, so that would solve the issues with an early block.
  6. rockable
    rockable
    Who makes the stamped upper control arms that add caster? I used CPP tubular on my 57 but if I do another tri five, I would like to use stamped steel.
  7. CTaulbert
    CTaulbert
    from Detroit
    They're also from CPP, part number 5557SCA-U5.
    rod1, guthriesmith and rockable like this.
  8. ***Area-51***
    ***Area-51***
    from Ohio
    Would you care to share the dish washer details...what ingredient was used to achieve the desired look?
  9. CTaulbert
    CTaulbert
    from Detroit
    We use Cascade Platinum Plus pods - and that's all it takes! The valve covers were freshly blasted before going in.
    ***Area-51*** and SS327 like this.
