57 Mercury Flywheel Question
Discussion in 'The Hokey Ass Message Board' started by Oldmics, Jul 3, 2013.
  1. Oldmics
    Oldmics
    So I mananged to get my mitts on the ultra rare bell housing to use a stick ****** on my Mercury 368 engine.
    So what do I use for a flywheel ?
    Anybody know if a truck flywheel for a 332 MEL engine will work?
    Oldmics
  2. drtrcrV-8
    drtrcrV-8
    Get on the Y-Block Lincoln thread & check out similar questions. One answer might be to carefully "lighten"(machine) a commercial flywheel from the '52-'64 big y-Block (not the 292" +/- series)to maintain the same outside diameter/ring gear as your 368 TP(ECU) engine.
  3. Lakehouse51
    Lakehouse51
    from Virginia
    Yep on the 332 302 341 317 got 2-you still lookin ?
  4. Oldmics
    Oldmics
    I got what I needed and also a spare :D
    Thanks to the H.A.M.B. groups and ProStockTom.
    Look for that Merc 2 door wagon sporting the M 335 setup next spring :eek:
    Appreciate you chiming in.
    Oldmics
  5. Lakehouse51
    Lakehouse51
    from Virginia
    WHAT YOU GOT LEFT? Save all cam core's that was the worst part of the build.
