Technical 57 Olds 88 pinion seal replacement help
Discussion in 'Traditional Hot Rods' started by sschreiner5, Sep 16, 2015.
  1. sschreiner5
    sschreiner5
    from Minnesota
    I need to replace the pinion seal on a 1957 olds 88. What is required to do this? I know sometimes there is a crush sleeve, sometimes you need to set pre-load and sometimes you just need to re-torque the flange. What needs to be done on a 57 olds? I hope to just remove the flange change the seal and put the flange back on, is it that easy for this one?
  2. oldrelics
    oldrelics
    from Calgary
    Well my '61 service manual says to replace the seal and then tighten 1/16" tighter. (mark the position of the nut and flange prior to removal). I think the '57 diff is pretty close to the same as a '61.
    Fab craft metal works sells parts for 57-64 olds diffs
  3. 302GMC
    302GMC
    from Idaho
    The seal is a simple matter of R&R. Pinion flange re-install is an acquired feel. On high mileage axles, I tighten the flange until just a tiny bit of preload is felt. You don't want any drastic changes in the tooth contact ... while you're in that far, service the u-joints & lube the emergency cables.
    Hnstray likes this.
  4. Two shabby
    Two shabby
    Take a small chisel and make a mark from the nut to the pinion. Take apart and replace seal. Tighten nut so the marks line up again.
  5. Mr48chev
    Add to Two Shabby's suggestion: count the turns on the nut when you remove it and install it with the same exact number of turns to the mark or 1/16th " past that mark.
  6. Rocky
    Rocky
    Classified Editor
    Having had a 56 with a pinion nut that came lose, I'd also put a dab of blue loc***e on the threads
  7. sschreiner5
    sschreiner5
    from Minnesota
    That's guys! this is what I was hoping for!
