Technical 58 Apache Power Steering Woes
Discussion in 'The Hokey Ass Message Board' started by 5th&Muscle, Jul 6, 2021.
  1. 5th&Muscle
    5th&Muscle
    I'm working on a buddy's 58 Apache with an SBC 350 and he wants power steering.
    6 different pumps from two different stores, all new hoses, new Ididit column, and two different steering boxes from CPP.
    The steering is fine while moving but it's when the revs are low that the *** ache begins. There's no ***istance at all when you're stopped and turning the wheel just cooks the fluid. We've bled and bled and bled by turning the wheel lock to lock, studied every GM guide, tried vacuum bleeding and nothing. It just refuses to cooperate.
    What am I doing wrong?
  2. greybeard360
    greybeard360
    What is the pressure at idle?
    Too large of pulley slowing the pump at idle?
    Too small of crank pulley?
    Without knowing the output pressure you are just guessing and throwing parts at it.
  3. squirrel
    is it this gear box?
  4. 5th&Muscle
    5th&Muscle
    How do you check the pressure? That's a good idea.
    The pulley is an OEM saginaw one, not sure about the crank pulley either.
    https://www.speedwaymotors.com/Blac...MDXyPYDhEhXS-HPvA5RIzNp4SjTDQU0hoC8iAQAvD_BwE
  5. 5th&Muscle
    5th&Muscle
    Yes sir sure is, with a Flaming River U-joint.
  6. squirrel
    how about some pictures of the pump setup you have on the truck?
    Also show us the outside of the truck, so we can see the wheels/tires.
    And have you checked the kingpins for binding?
  7. 5th&Muscle
    5th&Muscle
    Unfortunately the truck is no longer in my posession, but I will be able to get updated pictures from my buddy shortly. In the mean time, I had these saved on my phone. The hoses in the first picture have since been replaced.
    Regarding the kingpins, we did not check them. This was my first time working on an Apache so I'm a little unfamiliar with the steering linkage. Considering the condition of the rest of the truck, it wouldn't surprise me if they were totally cooked.
    Thank yall so much again for your help.
    64272551188__AAF489CA-94D9-43F2-B513-B0C5CA0E8882.jpg 64515599689__CA561077-93AB-4639-AD52-5D2F8C4B95B5.jpg 64272554034__C95BA52A-4049-4409-B5B0-2ABF2F93D9D9.jpg 64356976433__6F2C9297-EE7E-4B2E-A512-2A9566D6BAF3.jpg
    Jalopy Joker likes this.
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    Interesting. Pump is at quite an angle.
    Truckdoctor Andy likes this.
  9. squirrel
    You might make sure the belt is tight (a belt tension gauge is a big help here). And jack up the front of the truck, see if you can turn the steering wheel easily with the wheels off the ground.
    The wide tires and big offset wheels are not helping anything.
    When I first got my 59, after driving it for a year or so without greasing the kingpins every 1000 miles (that's what the owners manual says to do), they locked up...almost impossible to steer it when parked.
    Truckdoctor Andy and jimmy six like this.
  10. 5th&Muscle
    5th&Muscle
    The truck has no problems when jacked up off the ground - it steered like ****er.
    Now THAT is a great piece of information about it being locked up when it's parked. We could be on to something.
    That has been remedied since then, I apologize for the old picture but that's all I have at the moment.
    More pictures to come very soon, thank you gents.
  11. Doublepumper
    Doublepumper
    from OR-WA, USA
    squirrel likes this.
  12. carpok
    carpok
    from Indy
    C6950E33-0556-443E-B883-1477C171C542.jpeg 04DE7B2E-FCD4-47AD-A37C-64A24FAB7F4A.jpeg I have that same steering setup in my 57 truck seems like I had to in large the hole were the main shaft goes thru the frame. You sure it’s not dragging on the frame. My truck has big *** tires and has know problem turning lock to lock sitting still at idle. AB77FCAE-B6CD-4E14-BAAF-A68F4709AEFB.jpeg
  13. doyoulikesleds
    doyoulikesleds
    Whats with the welded pitman arm is it still the stock length if it was shortened it will take more effort to turn the wheels
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Depends on which end of the handle one turns with. But ya, what length is it vs one provided in kit form?
  15. carpok
    carpok
    from Indy
    Another thing the return port is on top by steering ujoint pressure is toward the bottom of box
  16. greybeard360
    greybeard360
    ^^^^^^ That could cause some issues if those aren't connected correctly.
  17. 1-SHOT
    1-SHOT
    from Denton
    You can change the pressure by adjusting the shims inside the pump. We use to use them on sprint cars a long time ago. Hope this helps. Also on GM steering boxes you can change the the torsion bar inside the box . The ones out of the heavier cars like Cadillac work well. Google brakeandfrontend.com . I figured all this **** out 50 years ago 7BDE3CC2-89E5-42A3-9EC5-B1B52BC8A48F.jpeg 67DE7DD9-4A29-4F3E-8810-2D7B77B3157C.jpeg 9446AB3D-C15A-43FC-83D3-6EB8F0227DBE.jpeg
  18. 5th&Muscle
    5th&Muscle
    Looks like it just had some reinforcement metal welded on.
  19. 5th&Muscle
    5th&Muscle
    Thank you again everyone for yalls help. We're going to prescribe getting the kingpins greased/looked at and then take it from there. If that doesn't work, we'll likely dive in to the pump.
  20. Elcohaulic
    Elcohaulic
    Did you remove all the washers from the pressure valve to get full pressure..
