Technical 58 Apache Water Temp Adapter
Discussion in 'The Hokey Ass Message Board' started by 5th&Muscle, May 4, 2021.
  1. 5th&Muscle
    5th&Muscle
    Hi everyone,
    I'm doing some resto work on my buddy's 1958 apache with a small block. He asked us to install reproduction gauges. The water temp probe is stumping us. I've tried numerous adapters - VDO 701-1799 "Adapter for mechanical temp gauge probe 5/8UNF to 3/8NPT" as well as AutoMeter 2264/3.
    The problem is the silver square nut makes it about 2 turns in to the adapter before it pops out. And screwing that square nut directly in to the engine makes it leak like a sieve, since nothing is making that probe seat.
    What kind of adapter do I need for this? Thank you!
    Picture attached
  2. Bob Lowry
    Bob Lowry
    This should do it...you need the adapter for the temp. bulb, so that it seals correctly. Used on most Chevys gauge.jpg
    from the 30's to the late 50's. Available at Napa and others..Balkamp part number 7011799
    vtx1800 likes this.
  3. 5th&Muscle
    5th&Muscle
    Awesome, thank you. Is this one different from the Autometer and VDO ones I listed above?
  4. Bob Lowry
    Bob Lowry
    Yes, the VDO and Autometer are designed for an electric sender, thus having a straight bore. The Napa type has
    a tapered bore, with a seating/sealing area for the manual temp. "bulb". The ridge on the top of the bulb
    will seat down, on top of the tapered bore, with the nut applying pressure. when you tighten it. Here's a better visual of the two types you're trying to match.
  5. squirrel
    strange, the 58 chevy trucks came with an electric gauge.
    The 55 had a mechanical gauge
    Johnny Gee likes this.
  6. Bob Lowry
    Bob Lowry
    Could it originally have been a 6 cylinder?
  7. squirrel
    55 with either engine were mechanical, 56-up with either engine were electric.
    My guess is that some company in china tooled up to make the 55 version, and it gets sold as a replacement for the other years, too.
    I just use original electric gauges and the TS-6 sender, but it's not easy to find good working gauges these days, unfortunately.
  8. 5th&Muscle
    5th&Muscle
    Do they make reproduction electronic gauges? I'm looking to retain as much of the factory look as I can.
  9. squirrel
    I don't know, I've never needed to buy one...I had a bunch of old clusters that I had collected at swap meets, etc over the years. Unfortunately I don't have any extras left.
  10. 5th&Muscle
    5th&Muscle
    Winner winner!
    This was it, thank you so much!
  11. Bob Lowry
    Bob Lowry
    Glad it worked out for you! Go HAMB!
