58 Biscayne 14 " wheels help ....
Discussion in 'The Hokey Ass Message Board' started by 62cadd, May 12, 2011.
  1. 62cadd
    62cadd
    Got a 58 Biscayne, and I had a set of 14' rims and www tires sitting around, since I got them for my old 60 Elky I thought they would fit no problem , well I threw them on and front left seems like is rubbing from the sway bar and on the top control arm, any ideas how to rectify this situation, I was thinking spacers but just want to make sure I'm not missing anything..
    Left side seems fine
  2. hotrod40coupe
    hotrod40coupe
    It must be the width of the tire you are using. My '58 Biscaynne came from the factory with 14" rims.
  3. FatDaddy53
    FatDaddy53
    60s 14" steelies arent all the same some are 2" deep lip on them...u can run the spacers but id switch out to a late 60's steelie or even the 80's g body cars had steel wheels
  4. 62cadd
    62cadd
    this is the way it looks
  5. 62cadd
    62cadd
    any ideas ?
  6. 61 chevy
    61 chevy
    i would replace those brake hose too, maybe a thin spacer
  7. dorf
    dorf
    from ohio
    looks like to much back spacing. those fronts are really ****ed in.
  8. 62cadd
    62cadd
    yeah I think I'm just gonna order some 1/2 inch spacers and call it a day..
  9. 1/2...will yer studs be long enough then? I think not...
  10. hammeredrods
    hammeredrods
    be careful with spacers ive heard and seen some horror stories with them . if you do run them check wheel nuts with a spanner every day
  11. brad chevy
    brad chevy
    Find the right backspace rims,spacers are **** and dangerous.
  12. 62cadd
    62cadd
    Any idea of where I can 2 of these rims.. ???
  13. brad chevy
    brad chevy
    Not to familiar with the yards in Kissimme but 98 AUTO PARTS hwy 50 Brooksville should have some.about a 40 minute ride from you. Also,if you have no luck there the Sumter swap meet is the 1st Sunday of the month,always pick some up there for 15 to 20 each.
  14. 62cadd
    62cadd
    Thanks Brad Chevy.. will look into that.
  15. DrJ
    DrJ
    I think the Elky came with wider brakes/hubs than the p***enger cars so the wheels are different back space?
  16. Lone Star Mopar
    Lone Star Mopar
    I thought the 58's were a one year only wheel, maybe thats why.
  17. THE_DUDE
    THE_DUDE
    Man, the fullsize Gm cars(57-64) ran a deep dish reverse rim.
  18. THE_DUDE
    THE_DUDE
    I think the 57-58 rims are the same ( three raised dimples to retain the hubcap)
  19. F&J
    F&J
    We used to look for station wagon rims. They are deeper dish. Less backspace. Some call them 409 wheels.
