58 chevy posi rear end info
Discussion in 'The Hokey Ass Message Board' started by 41blueoval, Sep 16, 2011.
  1. 41blueoval
    41blueoval
    Im puting a factory posi unit in a non posi case. 58 chevy. Looking at the unit itself it is not like a later spring/clutch pack unit, like a eaton. It has all steel clutch discs with no pressure at rest. Do the spider gears exert the force to make the posi lock? Does 57 to 64 posi unit require positraction gear oil addative like later units,synthetic lube ok to use? And lastly did 58,s have a different length axle for posi/non posi applications? Thanks in advance for advice.
  2. Bosco1956
    Bosco1956
    from Jokelahoma
    Axles will work 55 56 are theonly ones that need to be shortened.... Yes use a posi additive. I would not use Syn in it.
  3. 41blueoval
    41blueoval
    I thought i would answer my own question. I installed the factory 1958 posi unit in the 58 non posi housing. The axles seemed to be original and i DID have to shorten them. 1/8 on pass side and just over 3/16 on drivers side. Could i have had carry-over 57 axles?
  4. artificer64 likes this.
  5. 41blueoval
    41blueoval
    Thanks, I have that site saved. I used it when inspecting and assembling my unit.
  6. flyin54
    flyin54
    from modesto ca
    I did the exact install in a 58 and did NOT have to shorten the axles. Ran Dino lube and GM posi additive.
