58 edsel rear end
Discussion in 'The Hokey Ass Message Board' started by randy w, Sep 13, 2010.
  1. randy w
    randy w
    from tx
    Hello all;
    Is a 58 edsel rearend worth rebuilding? Is it the same as modern 9 inch fords and is it big or little ford wheel bolt pattern? Thanks
  2. frankenfords
    frankenfords
    from SoCal
    Definitely worth rebuilding. This will be the early style smooth back housing, look great under early cars. As far as width and bolt pattern, there are two versions. The 'small' Edsels used a Ford style rear which will be about 58 inches wide and have the 5 on 4.5 bolt pattern. The 'big' Edsels got the Mercury style rear which is about 60 inches wide and will have a 5 on 5 bolt pattern.
    A tape measure is your friend.
  3. randy w
    randy w
    from tx
    Thanks, guess I need to go back to the salvage yard and look.
  4. missysdad1
    missysdad1
    Be aware that the small Edsel brakes are not the same as '57-'59 Ford. They use a different, and unique, brake drum which was, when my Plymouth was under construction, very hard to find. All the parts including drums may be available in reproduction now, but it would pay to check before you put money out for the rear.
  5. Squablow
    Squablow
    Apparently all '58 Edsels, regardless of series, have a 5 on 5 bolt pattern. I always thought the Ranger/Pacer had 5 on 4.5" since they were based off of the Fairlane chassis, but that's not true.
    The Corsair and Citation rearend will most likely be wider.
  6. missysdad1
    missysdad1
    The Edsel rear axle under my '48 Plymouth is 58" wide and has a 5 x 4.5 bolt pattern. I'm pretty sure it's a '58 or '59. Brake parts do not interchange with same year Ford. It's been a long time since the car was built so the details are a bit hazy. Sorry.
  7. Squablow
    Squablow
    All '59 Edsels have 4.5" bolt pattern, all '58 has 5 on 5".
  8. edseldude
    edseldude
    from bedford va
    The 59 edsel rear end is the same as a 57-58-59-ford fairlane as far as width and bolt pattern. I narrowed the original rear end in my 58 and used the same backing plates just redrilled the drums to 5 x 4.5. The 58 ranger and pacer have a very wide rear end. I imagine the 58 citation and corsair are even wider as they are built on the mercury frame.
  9. I have a 58 Edsel rear in my GMC narrowed 10 inches and 4 3/4 bolt pattern Dutchman axles
  10. DRUGASM
    DRUGASM
    Check the options on the car too for the ratio. Mine is a freeway fly-er but not much round town. Its a 58 and its 5 x 5.
