58 edsel wagon trailer hitch questions
Discussion in 'The Hokey Ass Message Board' started by clean cut creations, Jan 2, 2007.
  1. clean cut creations
    clean cut creations
    I am new to pulling a trailer behind a vintage car and I was wondering where to start looking for a trailer hitch (preferably bolt on 'cause I am not welding a hitch to my 58 edsel wagon!) I have just purchased a 1954 Homesteader trailer and have plans for a restoration soon. I thought some hambers might be "TIN CAN TOURISTS" as well.
  2. The 58 Edsel is on the same ch***is as the 58 Ford or the 58 Merc, depending upon which model Edsel you have. Any hitch that will fit those will fit your Edsel. All are bolt ons.
  3. I'm in the same boat, but mines a 1959 Villager.
  4. I don't know how things are in other areas, but if you don't have a late model 'round here, you ain't buyin' a bolt-on hitch.
    So, do what I did, take a few measurements, and take a trip to the junkyard.
    You'll be looking at SUVs and pickups, as those are the closest in frame configuration to what you have. You'll need a good imagination, and a welder, to make it happen.
    And don't get a receiver with the hitch in it, as you'll play hell getting it out.
    Cosmo
  5. Grumpy
    Grumpy
    from NE Ohio
    What cosmo said.
    I plan on making a hitch from a newer truck fit my 53 chevy Suburban, to pull our little Shasta.
  6. clean cut creations
    clean cut creations
    Thanks guys! I guess I will have to fab up a bolt on one using a salvage piece........ I'll let you know how it goes.
