58 F100 with front mono leafs, What shocks? Last part I need to drive.
Discussion in 'The Hokey Ass Message Board' started by bird7263, May 4, 2011.
  1. bird7263
    bird7263
    I bought the reversed eye mono leafs from Sacramento Vintage Ford. I also bought the shocks and shackle kit. The shocks are on back order and they have no idea when they are gonna be back in stock. I need these to get it on the road. Does anybody have any idea what shocks to run or a part number. ???????????? I am starting to get frustrated. And when I call SacVintage they refuse to give me any vendor info so I can buy the shocks from somewhere else.. PLEASE HELP!!!!!!!!!!!!!!
  2. pigpin75
    pigpin75
  3. bird7263
    bird7263
    I have a flip in the rear as well and the 4 inch mono leaf drop in the front.. So you think these shocks will work. Meaning the numbers you gave? Thanks
  4. Hotrod1959
    Hotrod1959
    Or relocated the front stock upper mount up 3 inches and use stock shocks.
  5. bird7263
    bird7263
    My stock shocks are junk and need them replaced anyways. So I mise and well get the lowering ones. I just cant find the part number from the front and SacVintage is no help.
  6. matthew mcglothin
    matthew mcglothin
    I used rear shocks for gran torino..im guessing late 60's..my parts guy at orielys suggested them and they worked great..dont have pn though.
  7. bird7263
    bird7263
    Meaning you used the rear shocks of a Torino on the front of your F100 or on the rear?
  8. matthew mcglothin
    matthew mcglothin
    yep...on the front. Worked good
  9. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    I work at a Napa, I'll look up the part number @ Work and shoot you a text, chief.
  10. pigpin75
    pigpin75
    Grab a tape measure and see if the extended/collapsed measurements fit your application. If you do the leg work and find a set that fits it will be far less expensive with better selection of brands then if you just order whatever Sac Vintage has put together in their package
    You need to measure to insure the shock will fit before you spend your $
  11. bird7263
    bird7263
    Tim, let me know what ya find out.. My buddy that is doing the wiring is the Manager at the one here in Oregon City. I get a KILLER discount. Shit, I still owe ya $25 dont I?
  12. shocker998md
    shocker998md
    + 1 on measuring. Then you can run what ever you want as long as it mearsures out correctly.
