58 ford f100 v8 swap options?
Discussion in 'The Hokey Ass Message Board' started by punchdrunk, Sep 20, 2012.
  1. I Had a 58'. I Put a Late Camaro Front Clip On It. Now You Have Disc Brakes, Power Steering, and a 350 sbc. Just An Idea.
  2. y block is the way to go.. you need a y block bell housing, v8 radiator, I think the firewall part of the gas pedal is different on a v8 , and you have to move the fuel line to the other side. i think you could put in a FE using ford parts . they put 352s in 65, 66 f350s and 4wds
    and they still mounted th engine at the front and the bellhousing.
  3. moefuzz
    moefuzz
    Besides being a very anal "chevy lover", how much crack do you actually smoke each morning before breakfast?
    apparently it's a lot
  4. moefuzz
    moefuzz
    I thought it was "best at selling replacement cam lobes to the biggest heaps of sheeple"
    ..or was that crack smokin sheeple?
  5. 57Custom300
    57Custom300
    from Arizona
    IMHO
    1. Go the Y block route & contact Tim for great info.
    2. Keep it a 223
    3. FE
    Engine not to use. sbc
  6. punchdrunk
    punchdrunk
    from las vegas
    Yea I'm definately going with a y block sounds like a better option, I've found 1 near by actually to its about a hour drive its a 239 1954 Ford engine just wondering would this engine be a good reliable engine is supposed to be ready to run with automatic trans for $500 or wait and look for 292 or better motor
  7. Hate to say it but stay away from a '54 239. They use a different cam and are hard to do anything performance wise. Find a later 292 they are just as cheep and have more options.
  8. Exactly! Later model 292 or get a 312. If you.aren't worried about horse power or building a race motor...272 isn't bad either.
  9. jcmarz
    jcmarz
    from Chino, Ca
    You Ford lovers are so delusional:p
  10. fatkoop
    fatkoop
    I drove my '59 F100 for more than 30 years. Started out as a 292/3-speed. After rebuilding that engine twice I put in a 400M/C-6. I know, 400M's are not very popular, but I put more than 400,000 miles on that combo with virtually little or no problems. It can be done with very little or no welding, using a simple trans crossmember out of a '68 or '69 Ford (I think) shortened a few inches. The front mounts are super easy to build and I used the stock radiator. Even the 3 speed column linkage was modified slightly for the C-6. I did end up swapping the 4:11 rear to a more highway friendly 2:78 (or so). No racer, but cheap, easy, and dependable.
  11. derbydad276
    derbydad276
    Im sorry putting a chevy motor in a ford truck is like letting go a fart in church and blaming it on the old lady in front of you!
  12. coolbreeze1340
    coolbreeze1340
    from Indiana
    A Ford 429 police interceptor and a C-6 works well!!!!! If you want to stay on the cheap go pick up a wrecked Mustang (there is always a pile of them at the yard) and swap in the drivetrain. 20MPG on the highway and still enough power to have fun.
  13. hippy killer
    hippy killer
    im swaping my 223 out for a 440/727 dont really like crossbreeding but mopar runs good
